XL2420Z availability?
Re: XL2420Z availability?
Post by Chief Blur Buster » 23 Jan 2014, 21:26
silat wrote:"The FW of all the on hand or sold monitors are with no strobe timing issues.
Only the one that Blurbuster testing has issue, however, the one that
Blurbuster was testing is actually the engineering sample, not the MP sample."
Good to hear. Hopefully someone can confirm whether there is a strobe timing issue.
silat
Re: XL2420Z availability? [Be warned about strobe bug]
Post by silat » 23 Jan 2014, 23:43
Well I did not trust the answer. So I guess Ill wait before I purchase.
Post by Chief Blur Buster » 24 Jan 2014, 00:02
silat wrote:Well I did not trust the answer. So I guess Ill wait before I purchase.
Correct, because some of retail XL2720Z monitors STILL had the problem. It does not specifically affect only the engineering unit.
I am excited that BENQ is adding the adjustments, but I do recommend waiting.
TheRulesLawyer
Post by TheRulesLawyer » 24 Jan 2014, 13:09
Sadly, even if we get confirmation about a bug fix we won't know for sure if the bad ones have cleared the retail channel. I guess poor availability is good news until then.
srsbsns
Post by srsbsns » 30 Jan 2014, 19:52
XL2420Z in stock now for the USA! I swooped one.
http://shop.benq.us/monitors/gaming/xl2420z.html
Post by Chief Blur Buster » 30 Jan 2014, 22:00
srsbsns wrote:XL2420Z in stock now for the USA! I swooped one.
Excellent! I'd like you to do the motion test, and if it has any issues, to also test out the new workaround.
TheRulesLawyer
Post by TheRulesLawyer » 30 Jan 2014, 22:36
Sweet. Me too. Don't forget the coupon gamer$20.
Post by Chief Blur Buster » 30 Jan 2014, 22:46
You can also order 120Hz/144Hz monitors including the XL2420Z via the Blur Busters Official 120Hz List! -- these support the operation of Blur Busters.
mars
Post by mars » 31 Jan 2014, 03:49
Bought one about an hour ago!
Not since 2007, with a NEC CRT (R.I.P.), have I used a monitor that can do over 60Hz. I haven't been this excited about a computer upgrade in a long time :D
Oofloom
Post by Oofloom » 02 Feb 2014, 16:50
Just in case you guys don't know, there also an XL2411Z coming. Slightly lower input lag than the XL2420Z, but with fewer inputs.
