Questions about new G-Sync monitor
parini
Re: Questions about new G-Sync monitor
Post by parini » 01 Jul 2017, 12:24
This happens when you stay away from the gsync range with gsync on.
parini
Post by parini » 01 Jul 2017, 12:47
What does this technology monitor fixed refresh rate
Post by jorimt » 01 Jul 2017, 13:53
Does it happen on loading screens with G-SYNC and V-SYNC off?
parini
Post by parini » 01 Jul 2017, 15:00
Not only happens with gsync.
Post by jorimt » 01 Jul 2017, 15:06
Alright, so the only problem you are having with G-SYNC, is that the screen flickers (like an old film or movie), and only on loading screens?
I'm having a hard time understanding what you mean by "starts to shine like a star." Again, it would help to see it, but you say it is mild enough that you can't capture it with your camera.
Does it bother you that much?
parini
Post by parini » 01 Jul 2017, 16:30
Just happens when loading some game with gsync with high frametime, you once told me that it is normal to happen with panel tn
Post by jorimt » 01 Jul 2017, 16:50
If that is your only problem with G-SYNC parini, where it looks like it is flickering like an old film on loading screen only, as I told you before, that is normal for G-SYNC and some TN panels at very low framerates.
Again, nothing to worry about.
parini
Post by parini » 01 Jul 2017, 22:21
I was able to take the blessed sturttering after killing me so much I would only leave the fps unlocked, Gsync On + Nvidia Panel Vsync On + Fps unlocked.
parini
Post by parini » 01 Jul 2017, 22:22
Is it good to use this way the sturttering is finally over? Does this setting have inputlag?
Post by RealNC » 01 Jul 2017, 22:28
Yes. Unlocked FPS has input lag.
How were you locking the FPS before? With what software?
