Control monitor brightness using DDC/CI software?
Specular
Post by Specular » 10 Feb 2014, 20:54
Thought this would be the right place to ask, as you're all a knowledgeable bunch ;) . I've been interested in buying a Korean 1440p monitor, however the minimum brightness on many models is often too bright. From some searching it appears if a monitor supports DDC/CI in hardware there is software which can control the brightness to any level.
However some Korean models lack DDC/CI support, such as the Crossover 27Q LED-P, which has given me doubts as to whether they commonly support the feature. I've also read that if the graphics card lacks the driver support the feature mightn't work.
Does anyone here have experience controlling their 1440p monitor brightness using DDC/CI software controls?
There doesn't appear to be much info on this, but I did come across this thread on Overclock.net detailing some of the apps used.
shadman
Re: Control monitor brightness using DDC/CI software?
Post by shadman » 10 Feb 2014, 22:23
I don't know the technical aspects of this, but I'll input what I can.
I tried that utility with my Yamakasi Catleap, and it gave me the error "No supported displays found". Messing around with it a bit, I had the same message, ever time. This leads me to believe, plus what I've read up on that thread, because there is no OSD, or maybe not alto of internal controls or electronics, may be one reason these Korean brands may not work. Just my guess.
Of course you have f.lux, but that just matches the luminescence of the room, and doesn't really make it brighter or dimmer, and probably not quite what you need. It does have a feature to turn colors beyond the range they give you upon first install, but again, I believe it to not quite be what you need.
I've found a few other results that were easily-written programs using some version of .Net, but these are pretty similar in that they will darken the main desktop and windows, but menus when you right click, or the taskbar all the time, and mouse cursor are not dim. But still, the best solution I was able to find in a limited amount of time.
This is my favorite one here: http://download.cnet.com/Monitor-Bright ... 90260.html
This one here did not do anything for me whatsoever, but I believe that to be an OS incompatibility for my 8.1 install
http://www.nelsonpires.com/software/dimmer/
Specular
Post by Specular » 11 Feb 2014, 00:37
shadman wrote:I don't know the technical aspects of this, but I'll input what I can.
Thanks for trying the apps out and for the links :) Unfortunate that it didn't work on your display. Although I was looking for a way to control the native hardware brightness I did smile at the description of one of the apps linked,
"This program allows you to use your PC on hot summer nights leaving your windows open to refrigerate the room. Using this program will reduce the risk to attract mosquitoes, moths, and bats in your room."
Next heat-wave I know what I'll be using to keep the bats from invading my room :D
Post by Chief Blur Buster » 11 Feb 2014, 15:31
BTW -- Blur Busters now has an Overclockable 1440p IPS/PLS Monitor Guide.
Specular
Post by Specular » 13 Feb 2014, 03:05
Installed one such DDC/CI control app on a Dell (non 1440p) today to try it out, softMCCS (which I've seen used before for control brightness/luminance on monitors), and the brightness can only be adjusted within the monitors native range - no lower.
This came as a surprise as I was expecting the ability to lower the brightness further than the minimum :| It's really a shame manufacturers don't add better minimum brightness control, as it wouldn't cost them anything to do.
