BenQ UNIVERSAL 144Hz->220Hz OVERCLOCK for 1080p 144 Hz
- hleV
If your OC'd refresh rate profile is created properly and can be seen by the game, setting BF4's .exe to run at "Maximum Refresh Rate" in NVIDIA CP (or AMD's version of it) should do the trick.
BenQ XL2546K @ 240Hz (DyAC+) • ROCCAT Kone Pro Air @ 1000Hz • HyperX Alloy Origins • CORSAIR MM350 PRO Premium • HyperX Cloud Revolver • NVIDIA GeForce RTX 3070 @ 2130MHz/8000MHz • Intel Core i7-8700K @ 4.8GHz • G.SKILL RipjawsV 16GB (2x8GB) 3000MHz CL15
tharos96
NVIDIA CP is set to "highest available refresh rate" but ingame BF4 will only allow 144hz as the highest option. OORBuster running in the background.hleV wrote:If your OC'd refresh rate profile is created properly and can be seen by the game, setting BF4's .exe to run at "Maximum Refresh Rate" in NVIDIA CP (or AMD's version of it) should do the trick.
- hleV
Do other games run at OC'd refresh? You may need to create custom resulution via CRU in order for games to use it.
tharos96
I tried both the LCD standard timings and Chief's timings in CRU without success. Only NVIDIA CP seems to work for me :/
Here are the CRU settings I tried without success (No Signal) and the OSD message I get after some time with the pixel patcher enabled.
remka56
Hello guys , does 200 hz benq xl2720z work with dvi cable ? (playing cs go).
toptweaktopnotch
hi guys,
i did overclock my 2411z to 195hz stable and i really like it a lot (only using 195hz in games, WIN10 @120hz).
Thx to all involved people that make this tweak happen
i also use OORFixer.exe and it works absolutly fine. Good work!
@hleV i just saw in your description that u use 180hz on your 2411z, is there a reason and could u explain?
best regards boissssss
- hleV
Anything above 180Hz is not stable for me. It might work stably for hours in one game but go white screen in another, etc.toptweaktopnotch wrote:hi guys,
zn1p
Hi, guys
Tried the settings in nvidia cp on Xl2430. At 200hz I think I can see some kind of horizontal scanlines (the image is less solid, so to say, than at 144hz) and some shimmering. And at 210 and 220 the right side of monitor looks messed up (attached a photo), text becomes hard to read.
Am I doing something wrong? Blur reduction is turned off.
art1sta
Hello!
Works for me at 240hz with XL2420z monitor!! with one screen,ATI GPU and CRU(ToastyX) with the S-Switch trick!!!
But i have a lot of artifacts... maybe is for my configuration?
Config @ ToastyX
Active: 1920x1080
front porch: H=88 V=4
Sync width: 44 5
back porch 148 36
Some help will be apreciated!!
Config @ ToastyX
Active: 1920x1080
Sync width: 44 5
back porch 148 36
- hleV
Try lower refresh rate.
