Driver 441.08: Ultra-Low Latency Now with G-SYNC Support
shekur
Re: Driver 441.08: Ultra-Low Latency Now with G-SYNC Support
Post by shekur » 26 Dec 2019, 19:22
let's compare the two modes:
G-SYNC + V-SYNC (NVCP) + LLM "Ultra" w/138 (auto) FPS Limit
G-SYNC + Fast-SYNC (NVCP) + LLM "Ultra"
Display: Acer Predator XB271HU OS: Windows 7 Pro MB: ASUS z77-a CPU: i7 [email protected] GPU: Gigabyte GTX 1080 RAM: 32GB Corsair CMZ32GX3M4X1866C10
Post by jorimt » 29 Dec 2019, 10:44
shekur wrote:
26 Dec 2019, 19:22
Assuming the framerate can be sustained at the auto-cap in both these scenarios, then the input lag between the two would be about the same, with G-SYNC + Fast Sync causing recurring triple-buffer stutter, as Fast Sync is basically the only thing active when used with G-SYNC in this case:
https://www.blurbusters.com/gsync/gsync ... ettings/8/
Both scenarios would have around 1 frame more input lag than G-SYNC + V-SYNC + a typical in-game FPS limit.
poppe
Post by poppe » 06 Jan 2020, 12:14
New Nvidia drivers with FPS limiter, let's see some testing. 👀
Aeon
Post by Aeon » 06 Jan 2020, 12:56
soo now we have in-driver frame limiter.
now we only need comprehensive testing vs RTSS
Post by jorimt » 06 Jan 2020, 13:32
^ Too early to say for certain, but we do have precedence (at least with G-SYNC) from my earlier (non-official) tests of NULL here:
viewtopic.php?p=45250#p45250
With G-SYNC, I'm assuming the input lag levels are similar to NULL (probably tapping into the same limiting function), which are similar to RTSS (can't speak for frametime performance between the two), but simply allows a user set limit instead of auto.
Can't say when I'll have the time to formally test this, so the aforementioned should hold true for G-SYNC. As for my optimal G-SYNC settings, they haven't changed concerning this. Basically, if there isn't an in-game limiter available, and/or RTSS can't be used for any reason, use NULL or NVCP Max Framerate limiter.
Post by Chief Blur Buster » 06 Jan 2020, 21:23
Eventually, we'll have refresh rate well beyond game max framerates -- witness the ASUS 360 Hz announcement. A VRR range wider than framerate range, means a lot less worrying about what sync treatment you need at max Hz.
Ownsin
Post by Ownsin » 08 Jan 2020, 01:50
So now the optimal setup is G-SYNC + V-SYNC (NVCP) + LLM "On" w/141 FPS Limit (NVCP)
Or should I change something?
Post by jorimt » 09 Jan 2020, 13:11
Ownsin wrote:
08 Jan 2020, 01:50
viewtopic.php?f=5&t=5903&p=46121#p46121
Vleeswolf
Post by Vleeswolf » 11 Jan 2020, 11:49
Battlenonsense finds the new NVIDIA FRL perform as well as RTSS in BFV and Fortnite: https://youtu.be/W66pTe8YM2s
poppe
Post by poppe » 11 Jan 2020, 12:00
Still unsure what to set Low Latency mode to...
Guess I'll just set it to Ultra globally with the NVCP FPS cap.
And in games I'm more serious about like CS:GO I'll just use LLM "On" and use the ingame FPS cap.
We still don't know if Nvidia are improving the Ultra mode unless someone decides to test it every driver release..
