Incorrect native resolution(TV resolution) instead of PC XG2402
ko4
Post by ko4 » 26 Apr 2020, 19:36
Using the latest Nvidia drivers
I'm even using Displayport. These tv resolutions shouldn't even be showing up
Even if i use PC 1080p 144hz resolution, I can still modify sharpness in monitor OSD which should NOT be possible
Already did a clean install using DDU and reinitialized the monitor
Any ideas?
Re: Incorrect native resolution(TV resolution) instead of PC XG2402
Post by Chief Blur Buster » 29 Apr 2020, 02:59
ViewSonic XG2402, right?
This somewhat stumps me. Try doing a factory reset in the monitor menus to see if your XG2402 starts to behave normally. Try a different port on your GPU and on monitor.
Failing that, try a different better DisplayPort cable (not the one included with monitor, those box-ins are sometimes suprisingly high defect rate regardless of brand, ASUS, BenQ, Acer, ViewSonic -- the included DisplayPort cable is often low quality).
As a last resort ditch, turn the spaceship straight into the sun and try HDMI anyway -- create the custom resolution -- some gaming monitors support full Hz (144Hz and 240Hz) over HDMI. There is no refresh rate limit for HDMI and all recent NVIDIA/AMD cards can do 240Hz HDMI even over lowly 1.3a. 4K 60Hz and 1080p 240Hz is exactly the same bandwidth on HDMI. Any NVIDIA/AMD GPU capable of single-link HDMI 4K 60Hz can do 1080p 240Hz HDMI. Your weak link will typically be the limits of the HDMI chip built into monitor, and/or the missing Plug-n-Play EDID (necessitating a Custom Resolution to create 120Hz or 240Hz for HDMI).
ko4
Post by ko4 » 29 Apr 2020, 08:14
Chief Blur Buster wrote:
29 Apr 2020, 02:59
I've tried both HDMI and Displayport. Tv resolutions show up on both. I'm also using high quality cables and tried multiple
factory reset doesnt fix it
144hz does work when i switch to the PC resolution but the sharpness is still adjustable and I know that it should be greyed out instead from what i've read.
Is this something wrong with the nvidia driver or with the monitor?
axaro1
Post by axaro1 » 29 Apr 2020, 08:46
ko4 wrote:
29 Apr 2020, 08:14
29 Apr 2020, 02:59
I don't know if it will fix your issue but you can try to install the drivers and see if sometime change.
I couldn't find a way to change sharpness so I used SoftMCSS to change it xd
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
ko4
Post by ko4 » 29 Apr 2020, 09:08
axaro1 wrote:
29 Apr 2020, 08:46
Installed the "driver" and all it did was put a bunch of ICM files on my c drive
Is the Sharpness option in OSD greyed out for you?
If so you are already getting native sharpness you shouldn't have to change it
axaro1
Post by axaro1 » 29 Apr 2020, 09:18
ko4 wrote:
29 Apr 2020, 09:08
axaro1 wrote:
29 Apr 2020, 08:46
I couldn't find a way to change sharpness so I used SoftMCCS to change it xd
Yes, it is greyed out, that's why I use SoftMCCS.
Native sharpness is something like 75/100, which imo is too blurry, I prefer 100/100.
I use DP, I recommend you to avoid the default cable, it's not Vesa certified.
*= currently owned
ko4
Post by ko4 » 29 Apr 2020, 14:31
axaro1 wrote:
29 Apr 2020, 09:18
What is the date of manufacture of your XG2402 if I may ask? Its written on the back of the monitor
axaro1
Post by axaro1 » 29 Apr 2020, 15:23
ko4 wrote:
29 Apr 2020, 14:31
axaro1 wrote:
29 Apr 2020, 09:18
2017/10/09
*= currently owned
ko4
Post by ko4 » 29 Apr 2020, 15:40
axaro1 wrote:
29 Apr 2020, 15:23
ko4 wrote:
29 Apr 2020, 14:31
axaro1 wrote:
29 Apr 2020, 09:18
2017/10/09
I see, mine was manufactured in 2019 so the adjustable sharpness might be something they unlocked in newer firmwares
Or maybe its because I'm using an nvidia gpu. I know other monitors such as the aw2518hf also show tv resolutions in nvcp
tuvok_
Post by tuvok_ » 30 Apr 2020, 12:53
wow i got the same issue with the ViewSonic XG270 Elite
look:
when i change to PC-RESOLUTION screen is not smooth and clear.
I Just have 1920x1080p NOT Native with 240, 144 and 100Hz.
Any Recommendation for a high quality DP Cable?
