Locked
WayUpGaming
Post by WayUpGaming » 10 Jun 2020, 15:33
RLCS Contender, ty so much for your reply!
Reading more into this thread has me reconsidering buying the ASUS VG279QM tbh, did you not like the Acer Predator XB273X?
WayUpGaming
Post by WayUpGaming » 10 Jun 2020, 15:35
RLCScontender wrote:
10 Jun 2020, 15:31
Amazon gave me $800 amazon credit and 1 year free amazon prime cuz my brother who's an attorney contacted ofm for harassment.
tHey harassed me three times alleging fraud. Making returns isn't fraudulant. Policy is policy
If they ban me, i have a solid litigation case against them so im basically untouchable.
3rd party sellers hate me the most and if they ever charge a restock fee,i will file an a/z claim. Yes, i won all of them(7/7)
so which monitor are you planning on making your main?
fowteen
Post by fowteen » 10 Jun 2020, 15:47
What did they say that you did fraudently?
Ryno24
Post by Ryno24 » 10 Jun 2020, 16:00
Just got the MAG251 RX. Whats the best set up for fast paced FPS battle royal (Apex)? Why is everything so grey with it?
Post by Chief Blur Buster » 10 Jun 2020, 16:04
10 Jun 2020, 15:31
We have no comment on how users handle Amazon.
However... Blur Busters is an Amazon affiliate. This means some of Blur Busters income is paid for by Amazon purchases via commissions via Amazon links from Blur Busters. We have to protect our Amazon affiliate status..... so, please don't advertise this technique of frequent Amazon returns. Our affiliate status can be revoked if too many users of this site do this. It's risky to Blur Busters to let Blur Busters Forums users to advertise using Amazon returns as a technique of cheaply testing many monitors for the flawless model -- I have to protect Blur Busters ability to get affiliate income that pays for a percentage of revenues that keeps Blur Busters alive. Appreciated. Thank you.
Monitors are woefully imperfect and inconsistent -- you've clearly pointed out really major flaws -- but not all users are as picky about running the panel lottery. Amazon has sometimes made moves on small businesses and websites whose audience churn purchases too much -- and revoked affiliate status for sites who contains too many users who churn purchases -- unless some outside person is intentionally churning Amazon returns to destroy an affiliate (It happened to a person targetting another site -- and landed that outside person in legal trouble).
We keep a hawk eye on any funny activity in our Affiliate income for any strangeness... So far, everything looks within statistically normal parameters with no TOS red flags, and I want to keep it that way.
Appreciate the consideration of keeping this to yourself -- what is between you and Amazon, stays between you and Amazon. OK?
P.S. We are looking at additional (non-Amazon) affiliates too to give fans a choice, as I realize not every user is a fan of Amazon...
74tm
Post by 74tm » 10 Jun 2020, 16:06
10 Jun 2020, 13:18
My package just arrived this morning. First impressions(i'm at work right now so i will use my new custom built box(inside is a photodiode and a bunch of soldered wires and latency measuring hardware which connects BOTH to my oscilloscope and conmpyuter). The accuracy of my oscilloscope goes to the hundedths of 0.01
First impressions of the VG259qm
this is badly tuned because i was comparing my UFO tests with the vg279qm.
1. at 80 OD, the VG279qm looks SHARPER than the 60 OD of the VG259QM @240hz via UFO test. i got 3.7ms g2g on the vg279qm, i'm guessing @240hz, it's 4-4.2ms g2g at 60 OD @240 for the 25" version. The 60 OD on the vg279qm is SLOWER than the 60 OD on the vg259qm however. then again, why would someone who owns the 27" version of the monitor use OD 60 when OD 80 literally has little to no overshoot?
2. OD 80 is playable at 240hz but the occasional glowing blue artefacts to me is distracting, so OD 60 is FOR SURE the setting to use at 240hz. Also, when i'm going in super sonic speeds, the rocket league ground occasionally glows(it turns white) but no inverse ghosting artefacts. This reminds me of "advanced" setting on the viewsonic elite xg270qg, where the overshoot is SLIGHTLY too high to be playable but it wont' cause any artefacts to show, but u will see a delay in color transition if you go super fast. I'm OCD and if i see any distracting artefacts, to me it's not playable.
3. OD 80 is playable at 280hz and in practice I saw NO artefacts and or delayed color changes(tested this when i was goign in super sonic speed in rocket league) playing only two games of rocket league. I also moved my camera super fast to make sure and i didn't see any artefacts and i didn't. I also didn't see any black level smearing at OD 60 but i can tell when the ball is moving VERY fast, it wasn't as sharp compared to when i'm on OD 80.
so yes, my initial assertion at 280hz. OD 80 HAS to be used @280hz refresh so by default, it's the fastest monitor in the world on its optimal refresh rate oef 280hz. The overshoot just by looking at the UFO test is literally at the border of what i consider playable at 240hz and above (15%). Anything higher than 15% overshoot, to me it's too distracting
this is one of the mainm reasons why the LG 38gl850-b the 38" ultra wide monitor didn't even break my top 12 because those reviewers claim it has a fast g2g average but the overshoot is above 10%(which at 165hz and below is VERY VERY noticeable). At 240hz, i'm giving a 15% inverse ghosting error rate leeway since overshoot dissipates way faster and the added motion clarity(MPRT) is more powerful as well.
tldr;
this will come down to the overshoot error rate at 280hz. if i find that it's above 15%, this is an instant return.
so from 240hz and below, this monitor is SLOWER than the VG279qm bcuz of how badly tuned the settings are. However, at 280hz, it's faster than the VG279qm because 80 OD is sharper on the 25" version than the 27" version but with more inverse ghosting based off the UFO tests.
this all comes down to the ERROR % measurements of at 280hz on OD 80 . If it's above 15%, it's unplayable and this would be the worst 240/280hz IPS monitor in my opinion. But if it's at the 13-15%, that is totally acceptable and in practice u probably won't see it(then again, everyone is different). Only IF the FPS is consistently near 280hz or higher.
good news, the input lag at 60hz is snappy. This is just as good as the MSI MAG251rx and the alienware aw2521hf. So the input lag penalty for the 25" version does NOT apply at 60hz fixed refresh compared to its 27" version where input lag at 60hz is horrendous.
will report hard numbers and do rigorus rise time tests once i get home.
How do the colors and coating compare tot the other monitors. Also was the black light bleed too bad?
RLCSContender*
Post by RLCSContender* » 10 Jun 2020, 16:06
ok not a problem. i was just answering the guy's question but i went overboard when i added those details.
milojr21
Post by milojr21 » 10 Jun 2020, 16:21
Good stuff RLCScontender. Looking forward to seeing your results
Shyzo
Post by Shyzo » 10 Jun 2020, 16:28
Hey there.
Insane testing you did there. I did not read through all 39 Pages but I read the first and skipped through some of the others.
I am wondering why you said Backlight strobing is a must have for you since you use it to break a losing streak.
Is there a reason then why you don´t always use it in the first place? It apparently makes you play better!?
I am also currently on the struggle if I should get the AW2521HF (340€) or MAG251RX (399€) or VG259QM (350€).
Ryno24
Post by Ryno24 » 10 Jun 2020, 17:30
Ryno24 wrote:
10 Jun 2020, 16:00
I see when I turn it to FPS mode it makes everything more grey.
Locked
