BenQ Zowie XL2546K 240hz TN
Meowchan
Re: BenQ Zowie XL2546K 240hz TN
Post by Meowchan » 26 Oct 2020, 12:24
eSports is not your casual gaming use game. We are talking 10-16 hours a day of the same static HUD elements / Crosshair on screen for the entire duration, and medium-high brightness as well. It would also need to be running at at least 240 hz.
pox02
Post by pox02 » 26 Oct 2020, 16:06
i heard zowie locked the service menu in this model which is disappointing any work around this ? just bought it take month to arrive :( covid-19
AddictFPS
Post by AddictFPS » 27 Oct 2020, 10:14
Yes, but developers of eSports games can contribute to care OLED monitors, for instance in CS:GO is not needed see crosshair when players are selecting weapons at round start. This sure reduce crosshair burn in. If they make similar with the rest of UI, should help.
240Hz without BFI not seems a problem, this TV refresh pixels at this frequency internaly. 120nits with pure blacks is amazing native static contrast, clear dark zones, without excessive brightness in day outdoors, without color deviations due to altered gamma using Black eQualizer. Moreover, from input lag viewpoint, is better true static contrast than processed one, all signal processing take a bit of time, and in this market, each ms matter.
funn3r
Post by funn3r » 27 Oct 2020, 11:11
I ordered one today, hopefully it will arrive on Friday. If you have some tests which i should do, write them down.
Diesto
Post by Diesto » 27 Oct 2020, 15:52
Just got one today. What does the Strobe Utility do?
Post by Chief Blur Buster » 27 Oct 2020, 16:02
Diesto wrote:
27 Oct 2020, 15:52
For more information, see Motion Blur Reduction FAQ. Get used to enabling/disabling DyAc, and deciding if you like using it. Then read Strobe Utility as well as the Strobe Utility Adjustment HOWTO to help optimize.
P.S. If you hate the duplicate images, try 120Hz-182Hz tricks, as seen in CRT Nirvana Guide For Disappointed CRT-to-LCD Upgraders, since refresh rate headroom improves strobe quality and eliminates a lot of jittering & double images.
240Hz is high enough that it's a blur reduction method by itself (75% less blur than 60Hz) if you decide to turn off DyAc.
That said, many like DyAc, depending on how it is tweaked.
axaro1
Post by axaro1 » 27 Oct 2020, 16:30
Rtings purchased the XL2546k yesterday (together with the PG259QN), it's a matter of time before they review the two units.
Edit: There's a new review with ufotest pictures
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
Falkentyne
Post by Falkentyne » 27 Oct 2020, 19:58
axaro1 wrote:
27 Oct 2020, 16:30
That 60hz is double strobing.
You can tell by the extra number of UFO images behind the main one.
Stevie66
Post by Stevie66 » 27 Oct 2020, 20:13
Those ufo tests look really bad with DyAc off, but I guess you always use DyAc with the Benq anyway
pstn
Post by pstn » 27 Oct 2020, 23:47
Stevie66 wrote:
27 Oct 2020, 20:13
do we know if it's still better than the xl2546?
