0.6ms difference of input lag
Re: 0.6ms difference of input lag
Post by Chief Blur Buster » 15 Feb 2021, 12:59
samartian wrote: ↑
13 Feb 2021, 17:40
By the way, if I am to get the XL2546K , and I am not able to push more than .. lets say 160~ fps, will 240hz really be better than 144? (DyAc off)
Define "Faster".
Assuming same GtG pixel response time & similar panel processing latency (the tapedelay latency component), the refresh rate difference has benefits:
160fps at 240Hz has less latency than 160fps at 144Hz
160fps at 240Hz has less visible tearing than 160fps at 144Hz
There are caveats though, some panels can do a terrible job (for various reasons) at lower refresh rates. But that is not always the case for every single 240Hz monitor model.
samartian
Post by samartian » 15 Feb 2021, 15:18
15 Feb 2021, 12:59
samartian wrote: ↑
13 Feb 2021, 17:40
Define "Faster".
I see.
I'll probably get my new PC soon (thinking I7 11700K when its out w/ RTX 3070 (or 80, depends on the price by then) .. and then Im gonna need some help choosing between XL2546K or the PG259QN for FPS :)
untill then, 144hz is my friend..
