Good 1440p monitor with minimal ghosting/ invert ghosting/ blur?
Hi
I would like to purchase a new monitor for gaming.
Could someone recommend one with very little bluring/ ghosting/ overshoot?
I am not too fussed about the max refresh rate but I would love some G-Sync compatible panel.
Thank you
Thank you
Re: Good 1440p monitor with minimal ghosting/ invert ghosting/ blur?
Hi, Acer xb273ugx/ASUS XG27AQM/Asus PG279QM
I have Acer xv272ux(Freesync model) and really love this panel, TN clarity and no input lag, don't see there ghosting/blur or inverse ghosting, quality with the same panel should be little bit better with ASUS XG27AQM, but Acer has lower price.
Thank you for the replies.
I had seen the list of suggested monitors but it does not lead to reviews and is therefore if limited use.
Asus PG279QM
LG 27GP850
Alienware AW2721D
Check Hardware Unboxed reviews on youtube, they test for this.
LG 27GP850
Alienware AW2721D
Boomchakadah
Acer XV272U Kvbmiiprzx
VG258QM 280Hz TN (main)| XG2431 240Hz IPS | XL2540K 240Hz TN | XV252Q 1080p 280Hz IPS | XL2546K 1080p 240hz TN | AW2518HF 1080p 240Hz TN | XV240YP 1080p 165Hz IPS | XG2402 1080p 144hz TN | 27GL83A 1440p 144Hz IPS | XL2411P 144Hz TN | XF240H 144Hz TN
Thanks but as I said, I have already bought the LG 27GL850 b
Very happy with it. Amazing monitor.
Boomchakadah
That 170Hz Acer XV272U Kvbmiiprzx has less ghosting and better out of the box colors than your LG 27GL850 https://www.rtings.com/monitor/tools/co ... shold=0.10
Since you said that you're not too fussed about the refresh rate, I thought 170Hz would be enough. if you want a 240Hz 1440p, get the ASUS XG27AQM.
