Asus RoG Strix XG27AQM
TeKamine
Re: Asus RoG Strix XG27AQM
Anyone that might help me ?
Thanks
Thanks
- Discorz
- VIP Member
Use default Racing Mode and manually configure RGB colors for correction. Don't use HDR400.
dz520
Just got this monitor last week and I'm loving it.
I tried ELMB for the first time and I can't say I'm noticing a difference in-game but it's very obvious on the UFO test.
However, is it normal that ELMB increases the brightness?
Because I've heard techtubers always complain how ELMB actually decreases brightness and that monitors become borderline unusable because how dark they get.
Yet on this monitor the complete opposite is happening and it becomes too bright for my liking.
A bit of contrast and color tweaking made it manageable though.
TeKamine
@dz520, ELMB is always decreasing brightness, what you relate is weird.
@Discorz, racing mode is fade and milky, it is hard to recalibrate everything from that mode. HDR400 is the HDR gaming/cinema from ASUS/windows 10 HDR ?
Thanks
Thanks
Ch0b0
I noticed that I cannot select ELMB Sync in certain games like CoD:Warzone. I'm not sure why. I maintain typically over 120fps during gameplay. Is it not possible to enable ELMB Sync if adaptive sync is enabled in certain games?
dz520
I've also found ELMB Sync to be spotty.
It turns OFF constantly, I enable it whether on desktop or ingame and don't pay too much attention but when I check a day or two later I'll find it disabled again.
The game runs over 200fps average and I have an RTSS limit to 260fps. Why does it keep turning off?
I'll have to pay more attention during which scenarios it turns off and report back.
liquidshadowfox
elmb sync is always active for me as long as the refresh is above 80 hz. The moment you have a game with fps spikes below 80, it'll temporarily disable elmb sync.
hwanzi
hi, this is my first elmb monitor do I also enable ULMB in nvidia control panel to enable elmb sync or do I just keep it on fixed refresh?
- RealNC
I don't have an ELMB sync monitor, but my guess is you choose "G-SYNC" in the nvidia panel and then enable ELMB sync in the monitor's OSD menus.
- Worraps
Hi,
I would like to know if anyone else with a XG27AQM can replicate this and if it's normal or if there's a workaround. This didn't happen with my previous monitor.
So basically, I've purchased this monitor a few weeks ago and I've enabled G-Sync in the monitor OSD and globally in the NVCP for fullscreen only. All good and working as expected with V-Sync ON and games capped under 270 FPS. Not my first G-Sync capable monitor so I've done my research and how to properly enable it.
However, for competitive games like Valorant or CS:GO, I disable G-Sync on the games settings in NVCP since I feel some sort of input lag with it on so I simply want it disabled for those 2 or 3 games.
I go into NVCP and select:
Monitor Technology: Fixed Refresh
Preferred Refresh Rate: Highest Available
Vertical Sync: Use the 3D Application Setting
I do this to disable G-Sync on those specific games and by having the G-Sync Indicator ON and also by the slightly lower input lag, I can tell that the games are running without G-Sync.
However, on these specific games, ALT-TAB becomes extremely slow, screen goes black for a few seconds when ALT-Tabbing and the same again when opening the game. This happens on fullscreen mode and even on borderless.
My guess is that it is somehow changing refresh rate or something else when ALT-Tabbing, but it makes no sense since both the game and everything else non-fullscreen on the computer are running without G-Sync, so same mode. I swear I've tried every single setting possible and nothing works. The only way to get ALT-TAB to work as expected is by enabling G-Sync again on those games but as I don't want to play them with G-Sync, I've still disabled it and am trying to ignore the slow ALT-TAB.
Even worse, I use a program called DisplayFusion to make my fullscreen games not lose focus when I click on my second monitor or when I press the Windows Key, and this doesn't work on these games either, even though it works on every game with G-Sync ON.
Finally, if I disable G-Sync entirely on the NVCP, all games ALT-TAB fast with no exceptions as well. To this is a very specific situation and I don't know if it's fixable but what I can say for sure is that on my previous monitor, I always had G-Sync enabled and disabled it for a few specific games. This never affected my ALT-TAB speed.
Would like to know if this is happening to other people with the same monitor as me because if it's not, it can be Windows related.
Thanks.
Thanks.
