Bad mousetester graph when videocard is on
Anonymous768119
Re: Bad mousetester graph when videocard is on
Post by Anonymous768119 » 08 Nov 2021, 17:42
My results are looking pretty bad and so far I was not able to improve it.
If I hadn't experienced a point in my life, when mouse tracking was just 100% perfect (not in my place of course) and I could move mouse cursor in any place on desktop without even focusing much on it with mouse that I held first time in my hands, then I would think that what I presently experience is normal.
Chief's post is interesting, but I've been asked many times by electricians, how would any interference go throught PSU filtering? They are like 100% sure it's not possible and digital signal is so difficult to interrupt.
@Chief have you ever tried to connect oscope behind monitor's PSU with simulated interference? I've never seen any tests like that and perhaps it would answer some questions.
Post by Slender » 08 Nov 2021, 19:38
08 Nov 2021, 14:54
Slender wrote: ↑
08 Nov 2021, 12:39
chief, as you can see above, I have already purchased my pci-e usb 2.0 controller, and it has greatly improved my latency, even considering the fact that it does not have msi mode, unfortunately I encounter a problem on both controllers, I do not know what to do, I cannot find the exact culprit.
Post by Chief Blur Buster » 08 Nov 2021, 22:34
a_c_r_e_a_l wrote: ↑
08 Nov 2021, 17:42
<rant>
Not directed directly at you -- but this is a rant to old-fashioned analog-era-only-minded electricians who try to argue against the seriousness of certain digital-interference problems. Not directed at you, but frustrations directed to those analog-era electricians who say "big whoop".
Please ask the analog house-wiring electricians if they understand all the possible methods that interference can happen (including over-the air, bypassing power filters). Power filters help but it's only a few stone-bricks in a castle fort protecting you.
Please ask the analog house-wiring electricians if they have any university training experience with digital electronics.
Please ask the analog house-wiring electricians if they are familiar with Claude Shannon's Law.
Please ask the analog house-wiring electricians if they have any familiarity with some of the EMI engineering that NVIDIA does.
Please ask the analog house-wiring electricians if they are familiar with The Amazing Human Visible Feats of The Milliseconds, and how sometimes a millisecond cascades to human visible effects.
Please ask the analog house-wiring electricians if they are familiar with advanced digital error correction algorithms (forward error correction) running near the Shannon Limit such LDPC or Turbo Code or Reed-Solomon, or others. This is done to transmit information faster with less power without needing an upgraded medium. Now, when a medium is packed to a theoretical limit of the maximum data per unit of bandwidth & unit of power (e.g. metaphorically like a nearly overflowing river that can't widen anymore, or a pipe about to burst, etc), it is super-sensitive to disturbances. When such data is disturbed by minor interference, then it requires retroactive error correction (e.g. retransmissions, rereads, etc). That incurs a latency overhead. So interruption = latency, instead of cutouts.
Please also tell them I am in more than 20 peer reviewed research papers.
I will not remotely give the liberty of bothering to answer your electrican garbage advice until you confirm.
While digital signals are difficult to interrupt, they do cut out, much like a HDTV broadcast pixellating or a packet loss on a digital connection. When digital signals are operating close to the digital noise floor, having to use a combination of Reed-Solomon Error Correction Codes, or even Turbo Code error correction, or LDPC (Low Density Parity Check) error correction, the digital signals suddenly become several orders of magnitude easier to interrupt with the faintest possible EMI. One cable medium or a circuit path might see only a speed burp like 1 gigabits per second falling to 800 megabits per second (with temporary jitter) from minor interference, or whatnot. We don't notice because streaming merrily goes on, videos keeps playing, software keeps running, etc. But when in microscope, we're seeing micro-latencies from error correction. Maybe to THEIR OWN GODDAMN SEMANTICS, "a millisecond of lag is not an interruption at all", but that's a fat assumption (ASS out of U and ME) about how important a millisecond is to them, versus to us. So micdrop.
By "interrupt", the signal is not interrupted completely but simply error-corrected (creates lag = jitter). The first packet disappears, and a new packet has to be transmitted later.
Tell them modern USB is now packetized like an Internet backbone.
Tell them modern PCIe 4+ is now packetized like an Internet backbone.
Tell them modern SATA is now packetized like an Internet backbone.
Packet loss DO happen and it happens transparently; interference = error correction = simply retransmitted packets = latency.
Sorry, silly analog-era electricians that make assumptions of the unimportance of interference to digital, or that "inteference = loss of data", not understanding error correction. And the creation of latencies resulting from error correcting behaviours of computer components. Because the components are operating extremely close to Shannon's Theorem. This is happening because we've tried to push more data per second using the same amount of power as before, over the same copper wires, etc.
</numbertwo>
</toiletflush>
Thank you.
(I really mean it, unceremoniously, to self-righteous analog-educated people who don't quite understand the digital domain. They need to realize that EMI can go through multiple mediums instead of PSU filtering, as explained here. EMI is several orders of magnitude more complex than many electricians think. Mathematically. there's more possible theoretical simultaneous patterns/combinations of EMI than there are atoms in the universe, including over-the-air EMI that bypasses power filters (just LOOK, click the goddamned links, you old-era analog electricians). It is not necessarily a single frequency. Old-era analog-minded-only electricans need to intern as an NVIDIA circuit design engineer's assistant to be baseball-bat humbled by the major cascade effects of milliseconds worth of error corrections that cascades to stutters/latency/jitter/etc, and that different people are more sensitive to different things than others)
</rant>
Post by Slender » 08 Nov 2021, 23:45
08 Nov 2021, 22:34
but you must agree that these people are crazy, they blame electricity for everything, although they use unconfigured systems.
MegaMelmek
Post by MegaMelmek » 09 Nov 2021, 04:47
Slender wrote: ↑
08 Nov 2021, 23:45
08 Nov 2021, 22:34
Pls dont act like there is some setup on windows/bios thats bad cofigured…. When you buy new Gamimg PC it should handle simple game like CS GO without any aditional setup.
Post by Slender » 09 Nov 2021, 05:20
MegaMelmek wrote: ↑
09 Nov 2021, 04:47
Slender wrote: ↑
08 Nov 2021, 23:45
08 Nov 2021, 22:34
this confirms my words, chief, they don't even want to learn something new
Post by Slender » 09 Nov 2021, 05:31
this dude does not know what driver binding to individual cores is, enabling the msi mode, does not know that 1 frame in the pre-render for csgo dramatically reduces the delay, does not know that commands need to be disabled in the same csgo to free up the buffer for the mouse, has no idea what timers do and why they should not be touched, does not know how smooth curve x y affect the mouse, which chipset drivers need to be installed and which are not needed, does not know that the nvidia driver can be trimmed, does not know what the timer resolution is. I am silent about the bios settings and a simple disable c-state... but I'm sure he thinks he has dirty electricity.
MegaMelmek
Post by MegaMelmek » 09 Nov 2021, 06:12
Slender wrote: ↑
09 Nov 2021, 05:31
i thing you wrong mate… compare to purchasing new fast car you dont need to know where the fuse are where the injection are and so one. If they tell you that car can go 200Mph but as a born talented racer you can tell thats BS even if clock says it…. Thats same with PC mate if they offer them as gaming so i expecting they will work without any other setup to be use for gaming on competitive level o do not say pro level. Also i expecting that the older rig gets outperformed withou any other setup in all aspect.
Maybe i ask to much but to me do not make sens to make from V12 engine V11 and making that tweek superior because didnt make any sense. Thats the c state advice. Why not uderpower the cpu? These ferrari cars i see every day refuling with CNG. But is nice tweek
Post by Slender » 09 Nov 2021, 06:55
MegaMelmek wrote: ↑
09 Nov 2021, 06:12
Slender wrote: ↑
09 Nov 2021, 05:31
your elo?
MegaMelmek
Post by MegaMelmek » 09 Nov 2021, 07:19
now elo is the measurement to find out if the player is able sense input lag? realy?
2300 highest… that is 11months exatly the day a change PC since then i do not play faceit tha much only testing on DM….
Your elo? 🤣🤣
