240Hz Frameskipping Thread -- And Bugfixed Monitors
jensgram
Re: 240Hz Frameskipping Thread (UPDATE: fixed except XF270HA
Post by jensgram » 20 Sep 2019, 17:34
Chief Blur Buster wrote:Oh!
Damn -- You got the one 240Hz monitor (out of the 13 models now shipping) we haven't solved frameskipping in, yet. :(
Can you try HalfwayDead's numbers and post some smartphone photographs here? If you want to ship it back today -- I understand!
If you get a different 240Hz, then here is the whitelist:
AF251FZ -- frameskipping solved user-side
XG2530 -- frameskipping solved user-side (but they were also wonderfully fast to fix it in their firmware, too!)
XF270HA -- the one we're trailblazing
XG258Q -- untested
GSYNC 240Hz -- no frameskipping issue
I'll bump the Amazon gift certificate to $50 now. There is no expiration date -- this bounty remains good until someone finds ToastyX settings that fixes the frameskipping on an XF270HA.
XF270HA doesn't exist in our monitor lists because of frameskipping. We removed XF270HA from the monitor lists below a while back until the manufacturer has fixed it -- but I haven't heard back from Acer yet.
Did you ever find a solution to this problem? And do you know for sure that October 17 is the month that separate the bad screens with frameskipping from the better ones?
At the moment I'm looking at a XF270HA with factory month August 17, should I keep my fingers away from it?
A Solid lad
Re: 240Hz Frameskipping Thread -- And Bugfixed Monitors
Post by A Solid lad » 24 Sep 2019, 15:38
I'd suggest getting it only if there's an option to return it, in case it fails the framskipping test.
Discord | Youtube | Twitch
Worstylolzs
Re: AOC AG251FZ 240Hz frameskipping fix
Post by Worstylolzs » 07 Nov 2021, 14:12
05 Nov 2017, 12:28
I have not played with an Acer XF270HA frameskipping, so I am unable to give anything except a general rule of thumb. We know how to easily fix frameskipping on the AOC and ViewSonic monitors, and ViewSonic has fixed the frameskipping bug already. But I don't have any experience with Acer XF270HA yet.
If you could help us, we'd love to see if we can fix frameskipping together, so that I can update the instructions to also apply to Acer XF270HA monitors.
FreeSync does not have frameskipping
--> Turn on/off FreeSync. Frameskipping often disappears with FreeSync enabled
--> However, not everyone can turn on FreeSync (e.g. NVIDIA users). Also, one may prefer to use a fixed-Hz mode for VSYNC OFF operation in CS:GO.
But let's make VERY SURE that frameskipping is the monitor, and not by something else (e.g. drivers, software, etc). Microstutters are still visible at 240Hz, and should not be confused with frameskipping. To do so, do this:
For careful frameskipping verification without false positives
--> Make sure http://www.testufo.com/frameskipping is showing a green "READY.".
--> Web browsers can have a tough time running smooth at 240Hz. If you're not getting a green "READY." then temporarily force your computer performance to 100% (uses more electricity to prevent your computer from idling, but do this temporarily for this test)
--> Take a photograph of your screen with a camera exposure sufficiently long enough to capture at least 50 squares. (240Hz frameskipping is subtle -- 1 in 40 squares). If you're using an iPhone or Android, dim your screen's brightness quite a bit -- that forces smartphones to automatically take longer exposures (~1/5 second or longer preferred).
--> Repeat the photographing a few times. Observe how the frameskipping is happening, see how it's skipping every X frames.
--> Post these photos so we can help analyze.
Tweaks to Attempt
-- Download ToastyX CRU
-- Experiment with adding/removing numbers in ToastyX CRU. Remember to run "restart64.exe" everytime you change numbers, before viewing the TestUFO again.
-- Try increasing/decreasing sync.
-- Try increasing/decreasing porch.
-- See if number of frameskipped squares changes (e.g. 1 in 20 versus 1 in 40, etc). Note the behaviour changes.
-- You sometimes will have to add/remove 1 pixel at a time in CRU
I'd love to hear your results. It will help a LOT of other XB271HU users who might have the same issue (if it is genuine frameskipping).
Hello, i have frameskiping viewsonic xg2530. Need i do frameskipping fix in CRU if i play in G-sync compatible mode?
Thanks for answer.
Post by Chief Blur Buster » 08 Nov 2021, 11:02
VRR mode doesn't need frameskipping fix, as far as I know.
You can test www.testufo.com/frameskipping -- enabling VRR also fixes frameskipping -- but you can also add this manual CRU fix too, and still use VRR with this manual fix.
Worstylolzs
Post by Worstylolzs » 09 Nov 2021, 04:36
08 Nov 2021, 11:02
That's answer what i need! Thank you!
1AGRESSOR
Post by 1AGRESSOR » 13 Jun 2025, 04:24
GRAPHIC CARD: Sapphire 7900 XTX Nitro+ Samsung vRAM - ASIC 45%
OC vBIOS: 022.001.002.039.000001 - 20.11.2024 at 1:22:58 AM ( Updated ) GOP v.3.7.13 - 21.7.2023
OC/UV: Min 2820MHz Max 2920MHz / VRAM Fast Timings 2714MHz / PL +15% / mV 1125 )
3 separate rails/cables NO daisy chaining
MONITOR: Asus ROG Strix XG32WCMS ( Manufactured - October 2024 / Driver v.1.0 - Firmware v.MCM105 )
( NOT stated on Asus site but monitor natively supports 8-bit + FRC = 10-bit at 280Hz by default > CRU unlocked 12-bit at 284.035Hz )
CRU OC/Timings SETTINGS: https://imgur.com/a/xAmFS3n
Factory Hidden Menu + OSD Settings and Bias LED: https://imgur.com/a/RO5e13Q
( GPU DP-1 and Monitor DP are connected with "Club 3D CAC-2068" Cable )
is this frame skipping or some other issue ? ? ?
happens on default settings at 60Hz, and CRU OC settings
tested in Edge browser, see all pics
https://imgur.com/a/CDuhTq5
Thank you
EDIT: found the solution, there is a "BUG" in communication between frame skipping test and adrenaline settings, see the link
https://www.monitortests.com/forum/Thre ... 7#pid17507
