delete
1mongus
delete
Post by 1mongus » 02 May 2022, 15:22
Re: 60fps at 60hz vs 60fps at 240hz
Post by RealNC » 03 May 2022, 07:11
With gsync, and if the monitor's VRR is actually good, then it doesn't matter. You can use 240Hz and get perfect smoothness at 60FPS. If the monitor's VRR is not that good, then 60FPS@60Hz with vsync should be the most smooth you can get, unless the game's renderer has issues, in which case you need an FPS limiter on top, set slightly higher than your monitor's exact refresh rate (if your monitor is 59.95Hz, then you'd cap to 59.96FPS,) to smooth out the game's frame pacing.
You can measure the refresh rate here:
https://www.testufo.com/refreshrate
Also note that the refresh rate changes very slightly if you enable/disable gsync in the nvidia panel.
1mongus
delete
Post by 1mongus » 03 May 2022, 12:59
Post by RealNC » 03 May 2022, 13:41
1mongus wrote: ↑
03 May 2022, 12:59
The refresh changes slightly? How so?
I don't know the technical reason for it. But it does. The difference is very small. Like 239.953Hz vs 239.948Hz.
Also, do you think the Samsung Odyssey G7 has good VRR?
No idea. There's no reviewers I know of that test the VRR quality of displays. It's as if nobody cares. The only way to know is to get one.
1mongus
delete
Post by 1mongus » 05 May 2022, 06:07
Post by RealNC » 05 May 2022, 06:46
1mongus wrote: ↑
05 May 2022, 06:07
I actually own one, how would one tell if it has good VRR?
It it doesn't stutter or flicker when running 60FPS at 240Hz. So basically if you run a 60FPS-limited game at 240Hz with gsync enabled, and it looks the same to you as when running it at 60Hz, then that's a good indication that it works well.
