qwerty1234
Post by qwerty1234 » 11 May 2022, 18:24
dear user, could you suggest a few presets for cs go I will be VERY grateful... sr for my englado :с
nofearek9
Post by nofearek9 » 12 May 2022, 12:33
nofearek9 wrote: ↑
09 Feb 2022, 08:45
i have 2 PCs connected on my monitor one with HDMI and one with DP cable with my LG i had diferent profiles/setting for each port and when i was changing the input all the settings changed according to the port i was using,does asus have similar setup ? Or all the settings you change for 1 port are the same for all ports ?
anyone know if this can be done with this monitor ? 2 connections in the monitor with different settings.So each time i change input selection i don't have to change all that setting....
Scr1pts
Post by Scr1pts » 14 May 2022, 16:11
@axaro1
Ty for the response. Do you think OD 120 is good with 240hz?
Scr1pts
Post by Scr1pts » 14 May 2022, 16:12
axaro1 wrote: ↑
10 May 2022, 01:41
Scr1pts wrote: ↑
09 May 2022, 16:41
Hi @axaro1 what overdrive is best for 240hz?
OD60
Scr1pts wrote: ↑
09 May 2022, 16:41
And can I see the chart of od120 at 240hz
I can't because I'm using RTings response time tables that are limited to 280hz.
@axaro1 ty for the response. Do you think the OD120 is good with 240hz?
axaro1
Post by axaro1 » 15 May 2022, 00:18
Scr1pts wrote: ↑
14 May 2022, 16:12
no, it has way too much overshoot.
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
alexsacob
Post by alexsacob » 15 May 2022, 04:01
@axaro1
Hello friend, thanks for all this information that you have offered that has helped me despite not having this monitor, but it is one of the options that I was looking to buy.
I just opened the following post asking for help comparing the VG259Q Vs. VG249Q viewtopic.php?f=2&t=10015&p=80771#p80771
But when I saw your post I had doubts. I never manage to get above 140 fps in games (currently Apex Legends) and stick to around 100-130 using less than FHD resolution.
Is it worth investing more money in the VG259QM for those 280hz? For that price, are there better options?
What is the difference between these 3 monitors and which one do you think I should choose? I would greatly appreciate your opinion, advice and if you would visit the post I put up above.
Many thanks.
axaro1
Post by axaro1 » 15 May 2022, 16:03
alexsacob wrote: ↑
15 May 2022, 04:01
I think that Discorz recommendation to get the 24G2ZU is the wisest choice, especially considering two things:
1) It's less expensive than the VG259QM in your region
2) It has a newer panel with a good motion blur reduction implementation
*= currently owned
jtx
Post by jtx » 21 May 2022, 01:02
@axaro1
I recently purchased the VG259QM to mainly play CS:GO and was wondering what were the best settings in your opinion for it?
I have at the moment 280hz, OD120, SB 2, VividPixel 25 but from time to time I get a bit of shutter while playing, could it possibly be these settings? thank you in advance, appreciate all your help!
axaro1
Post by axaro1 » 22 May 2022, 02:37
jtx wrote: ↑
21 May 2022, 01:02
@axaro1
Can you elaborate on your stuttering issue? Could it be caused by tearing? Have you tried Adaptive Sync ON?
*= currently owned
hardt
Post by hardt » 24 May 2022, 17:51
@axaro1
I have a doubt
I'm going to play valorant with 240 hz the best configuration is to use OD60 with g-sync on racing mode with ICC from rtings and shadow boost level 2 and ELMB off?
sorry for the english i used the translator
