Could you record some short video at least? How you aim on bots or on deathmatch server. Thank youdervu wrote: β05 Jan 2023, 06:16Yes. It was not as extreme as some people show where most of the bullets don't hit, but it was enough to tell something was off. What was always worse than desync was inconsistency in inputs and overall game physics feeling weird.delve wrote: β04 Jan 2023, 20:31Did you have problems with peeking and hitreg before using this transformer thing?dervu wrote: β04 Jan 2023, 14:37
If by prefire you mean that every player looks like they prefire you every time, then no - it is not there.
Hitreg and peeking - no bullshit things. Movement and aiming feels exactly the same offline as online.
Mouse feels completely free. Light, but not floaty, same for keyboard inputs, character feels light.
The real reason why so many Eastern Europeans have input lag
CeaniD
Re: The real reason why so many Eastern Europeans have input lag
TheKelz
Question I have is, did you have an issue with stutter while scrolling on websites in any browser, making it feel like it's also desynced?dervu wrote: β05 Jan 2023, 06:16Yes. It was not as extreme as some people show where most of the bullets don't hit, but it was enough to tell something was off. What was always worse than desync was inconsistency in inputs and overall game physics feeling weird.delve wrote: β04 Jan 2023, 20:31Did you have problems with peeking and hitreg before using this transformer thing?dervu wrote: β04 Jan 2023, 14:37
getuliofmj
Which DC Blocker do you use?dervu wrote: β04 Jan 2023, 08:36So far it fixed it completely. It has been only 2 weeks.cybepine wrote: β04 Jan 2023, 08:02Good tip.dervu wrote: β04 Jan 2023, 06:22I will add one more tip. To be on safe side use DC blocker at transformer input, either external one or ask for built in one. It will get rid of buzz and make sure it is performing without saturation. Unless there is no DC present at all on grid and there is no transformer buzz.
My unit is almost completely silent.
Did balanced isolation transformer fix your issue? Completely, partially or none at all?
My unit is so silent I have to stick my head close to it to hear anything - with DC blocker.
I can only find weak options...
- dervu
Tomanek DCB-1.getuliofmj wrote: β06 Jan 2023, 19:12Which DC Blocker do you use?dervu wrote: β04 Jan 2023, 08:36So far it fixed it completely. It has been only 2 weeks.cybepine wrote: β04 Jan 2023, 08:02Good tip.dervu wrote: β04 Jan 2023, 06:22I will add one more tip. To be on safe side use DC blocker at transformer input, either external one or ask for built in one. It will get rid of buzz and make sure it is performing without saturation. Unless there is no DC present at all on grid and there is no transformer buzz.
- cybepine
We don't give here a dangerous advice. I know the danger this possesses and because of that I won't even try (test) it myself.adelsa123 wrote: β04 Jan 2023, 17:32can u provide screenn shhot of those steps in ur home ! Socket -> DC blocker -> Cheater plug to not have ground connected* Danger! Skip this! -> Balanced transformer -> RCD device** -> Powerbar with double pole switch*** -> Routers & PC & Monitor
u will help alot here ty
My setup:
Socket -> Balanced transformer -> Power strip with double pole switch (1.5m) -> Lamp & PC & 5.1 set & Monitor & Router(2m)
Total cable length 3.5 meters. The cables should be as short as possible.
- MY SETUP
- setup.png (875.7 KiB) Viewed 9878 times
itsjNs
So the toroidal balance isolation transformer fixed input lag and slow/heavy lag feeling??
itsjNs
Can someone confirm if the transformer fixes slow heavy input lag type feel .
adelsa123
i dont thhink so i talked with him in private message and he said i didnt hhave such probleme of slugish mouse delayed mouvement :
the only fix for people who claimed thhey fixed it is to movee to anoother place and test !
assombrosso
Canβt confirm unless I see video and kdr/stats going up after change
delve
If a power station didn't help you, I don't think this device will.
