I answered you here:
viewtopic.php?f=5&t=10505&p=85271#p85271
jorimt wrote: ↑26 Sep 2022, 08:18Whether the auto FPS limiter of G-SYNC + NVCP V-SYNC + Low Lantency Mode "Ultra" will engage is game-dependent. It also typically doesn't engage in DX12 or Vulkan.daninthemix wrote: ↑26 Sep 2022, 02:00G-sync + V-sync ON + NULL
In the above scenario, will the frame-rate always be capped below the refresh rate, even in DX12 / Vulkan games that ignore the MPRF setting? And will they do so only with G-Sync enabled (i.e. only in full-screen mode)?
I had previously done a test of some of my own games at one point to see when it would and would not engage:
Basically, it's not reliable as a global framerate limiter, since it doesn't always apply to every game.G-SYNC + NVCP V-SYNC + LLM Ultra @165Hz
158 FPS Auto Limit:
– Amid Evil (DX11)
– Battlefield 1 (DX11)
– Control (DX11)
– Counter-Strike: Global Offensive (DX9)
– Deus Ex: Mankind Divided (DX11)
– Hollow Knight (DX11, Unity)
– Journey To The Savage Planet (DX11)
– Overwatch (DX11)
– Tom Clancy’s The Division 2 (DX11)
– Valorant (DX11)
– We Happy Few (DX11)
No 158 FPS Auto Limit:
– Battlefield 1 (DX12)
– Call of Duty Warzone (DX12)
– Control (DX12)
– Deus Ex: Mankind Divided (DX12)
– Doom 2016 (Vulkan & OpenGL 4.5)
– Doom Eternal (Vulkan)
– Journey To The Savage Planet (DX12)
– Outward (DX11)
– Tom Clancy’s The Division 2 (DX12)
– Yooka-Laylee and the Impossible Lair (DX11, Unity)
You can achieve virtually the same thing globally with G-SYNC by using G-SYNC + NVCP V-SYNC + LLM "On" (note: LLM won't engage in all games, and not in DX12 or Vulkan at all) + manual NVCP Max Frame Rate FPS limit.
Do you have Reflex enabled? Because it also automatically limits the max framerate to ~224 at 240Hz with G-SYNC + V-SYNC.binodynamic wrote: ↑24 Jan 2023, 06:14Even when I have Ultra Low Latency mode “off” it still auto limits fps when I have gsync and NVCP vsync on. Any idea if a recent Nvidia Driver update made it so that no matter what your ULL setting is your fps is capped if you have gsync and NVCP vsync enabled? Although I’m only losing 12 fps since it would be at 237 without the auto limit It’ll be nice to have the extra frames.
I tested g-sync on, NVCP v-sync on, ULL off, and reflex disabled in-game but it still capped my fps at 225. This happened on Destiny 2 and Fortnite. However on Apex Legends even with ULL on and reflex + boost enabled in-game it doesn’t auto limit the fps to 225.jorimt wrote: ↑24 Jan 2023, 09:22Do you have Reflex enabled? Because it also automatically limits the max framerate to ~224 at 240Hz with G-SYNC + V-SYNC.binodynamic wrote: ↑24 Jan 2023, 06:14Even when I have Ultra Low Latency mode “off” it still auto limits fps when I have gsync and NVCP vsync on. Any idea if a recent Nvidia Driver update made it so that no matter what your ULL setting is your fps is capped if you have gsync and NVCP vsync enabled? Although I’m only losing 12 fps since it would be at 237 without the auto limit It’ll be nice to have the extra frames.
If you truly have LLM and Reflex "Off" (and you don't accidentally have an Nvidia Max Frame Rate, RTSS or in-game limit in place) and are still experiencing the ~224 FPS auto limit with G-SYNC + V-SYNC, it must be a glitch in the affected games (and/or the driver install).binodynamic wrote: ↑26 Jan 2023, 02:25I tested g-sync on, NVCP v-sync on, ULL off, and reflex disabled in-game but it still capped my fps at 225. This happened on Destiny 2 and Fortnite. However on Apex Legends even with ULL on and reflex + boost enabled in-game it doesn’t auto limit the fps to 225.
I wonder if enabling g-sync and v-sync NVCP simultaneously regardless of ULL or reflex settings automatically caps the fps on certain games.
Again, short of a glitch, not in my experience, and not that I know of.binodynamic wrote: ↑26 Jan 2023, 02:25I wonder if enabling g-sync and v-sync NVCP simultaneously regardless of ULL or reflex settings automatically caps the fps on certain games.
Wanted to inform this is no longer the case, though haven't yet tested myself.
Thanks for the heads up, I'll take a look.Kyouki wrote: ↑24 Jan 2024, 09:05Wanted to inform this is no longer the case, though haven't yet tested myself.
"Adds support for NVIDIA Ultra Low Latency Mode with DirectX 12 titles"
Per Nvidia driver update 551.23.
https://www.nvidia.com/Download/driverR ... 113/en-us/
Please poke me here and let me know! Very curious to your results as well.jorimt wrote: ↑24 Jan 2024, 09:48Thanks for the heads up, I'll take a look.Kyouki wrote: ↑24 Jan 2024, 09:05Wanted to inform this is no longer the case, though haven't yet tested myself.
Did you have time to thoroughly test Low Latency Mode for DX12. On my side games work without a hitch, always 138 cap when set to Ultra. Hoping that same would be done for Vulkan since Ultra Low Latency feels more natural to use with G - Sync for me...
