CS GO Input Lag
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 09 Jul 2023, 19:29
Went to friend 220km from me,played on his PC ,exactly same problem - online lag , offline no lag . I dont know what to say :lol:
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 12 Jul 2023, 10:28
Anonymous wrote:
09 Jul 2023, 19:55
Are you able to show your autoexec.cfg + launch options? https://pastebin.com/
Last days i reinstalled windows and csgo 7-8 times , im using default cfg and no launch options or only -novid . I dont understand the link and what i should do,tell me if it is important. Im very close to sell again and give myself rest,Its exhausting and annoying...
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 12 Jul 2023, 10:40
Anonymous wrote:
12 Jul 2023, 10:31
Sure you have.
Its hard for me to understand,sorry .Im using google translate most of the time.
This is my cfg if you ask for that https://www.mediafire.com/file/cqfmim2z ... g.cfg/file
but it is default cfg with changed hand,crosshair,etc
delve
Re: CS GO Input Lag
Post by delve » 12 Jul 2023, 12:22
you maybe should also try different games to rule out that is csgo.
Btw. I too feel a difference with keyboard lag offline vs online when training special jumps that require perfect timing, like there is some weird delay or randomness to it, but the difference doesn't feel as severe as you describe. You also mentioned "trouble killing from behind", that sounds like classic desync for me.
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 12 Jul 2023, 12:39
delve wrote:
12 Jul 2023, 12:22
I tried cs 1.6(steam and non steam) , condition zero,cs2 same lag in all these games,but also i tried dota2,i never played dota ,but i couldnt feel any problem there. Yes yes not only from behind,every kill is a struggle. Offline i need to move my mouse for 3 seconds to understand that its completely different mouse movement than online.
delve
Re: CS GO Input Lag
Post by delve » 12 Jul 2023, 13:34
yeah, non source game i mean, the problem i have is in a source mod, too.
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 12 Jul 2023, 14:22
Anonymous wrote:
12 Jul 2023, 14:05
SKILLEN wrote:
12 Jul 2023, 10:40
Anonymous wrote:
12 Jul 2023, 10:31
Sure you have.
Ok, try this autoexec + launch options that are above.
https://github.com/Anonymous/gaming_os_tw ... toexec.cfg
You don't expect to fix your problem by staying everything at default, right? Tweaks and Custom configs are available to fix / help with these kind of problems, including reduce/remove different types of latency. One of them could as well be what is causing your problem.
I think you missed when i said that i spend 5 years and thousands of hours trying every single tweak that exist in the internet ,every command, and read every thread that include input lag. And this was waste of time, in my first 18 years of cs i never had any problems ,never knew what lag or tweak is. Just disable vertical sync and play.
Yes i expect when i dont have problems offline with mouse,to not need to add extra commands to feel the same online :lol:
Of course i tried clean cfgs and every commands xxx times ,first time 2018 ,but due to respect for trying to help me,i tried again with your link , no improvement.
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 12 Jul 2023, 17:04
Yes, probably there is little improvement from tweaks ,but on already normal gameplay,if you have problem you can't tell the difference.
i'm on this stage where i need someone to discuss - just something that could cause this,not for entire solution,because the problem is weird and unsolvable for now.
Probably its not software - reinstalled win 7,8,10,11,linux many times, tweaks,everything
Probably its not hardware - changed 7pcs and played on 4-5 more ,mice,monitors,keyboards
Probably its not electricity - no problems offline, problem still here with generator
Probably its not internet - in the moment i have 3isp in my home ,total ISP tried - above 10 + starlink
Travel to 2 different locations both 200km+ from home
If i see someone else wrote all of this i would say the guy is crazy :lol:
delve
Re: CS GO Input Lag
Post by delve » 12 Jul 2023, 17:12
What about your friends pc, is he able to play at a high level? Better than you?
SKILLEN
Re: CS GO Input Lag
Post by SKILLEN » 12 Jul 2023, 17:13
Of course its sound like BS i already said that in the last row.
But do you think guy who play cs from 2000 and never had lag for 18 years with this faceit statistics in 70% solo q and 25% duo q will waste his time for years to fix something that dont exist ?
+ in previous pages i have clip how i aim offline with 60fps ,again do you think a guy who can aim like this with 60 fps will spend his time on forums to fix non existing probolem ?
https://www.faceit.com/en/players/-SKILLEN
https://www.faceit.com/en/players/sas0ry
