Please help me solve the power management of the mouse "Allow the computer to turn off this device to save power" is gra
Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.
Re: Please help me solve the power management of the mouse "Allow the computer to turn off this device to save power" is
So this setting is disabled through the registry or the mouse driver does not support power saving management.
All power saving options must be disabled, they affect mouse latency!
How do I disable it via the registry? Thank you for your answer
https://imgur.com/k4d2I6HSyykfk wrote: ↑08 Aug 2023, 16:36Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.批注 2023-08-09 052834.png
Everyone have like this by default, why you need to enable it?
Does gray mean not enabled?eropsy wrote: ↑09 Aug 2023, 04:59https://imgur.com/k4d2I6HSyykfk wrote: ↑08 Aug 2023, 16:36Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.批注 2023-08-09 052834.png
Is this option grayed out for everyone?eropsy wrote: ↑09 Aug 2023, 04:59https://imgur.com/k4d2I6HSyykfk wrote: ↑08 Aug 2023, 16:36Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.批注 2023-08-09 052834.png
yesSyykfk wrote: ↑09 Aug 2023, 11:27Is this option grayed out for everyone?eropsy wrote: ↑09 Aug 2023, 04:59https://imgur.com/k4d2I6HSyykfk wrote: ↑08 Aug 2023, 16:36Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.批注 2023-08-09 052834.png
Syykfk wrote: ↑09 Aug 2023, 10:26Does gray mean not enabled?eropsy wrote: ↑09 Aug 2023, 04:59https://imgur.com/k4d2I6HSyykfk wrote: ↑08 Aug 2023, 16:36Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.批注 2023-08-09 052834.png
Thank you for your answer, thank you very much!eropsy wrote: ↑09 Aug 2023, 11:59yesSyykfk wrote: ↑09 Aug 2023, 11:27Is this option grayed out for everyone?eropsy wrote: ↑09 Aug 2023, 04:59https://imgur.com/k4d2I6HSyykfk wrote: ↑08 Aug 2023, 16:36Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.批注 2023-08-09 052834.png
Hi!Syykfk wrote: ↑08 Aug 2023, 16:36Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.批注 2023-08-09 052834.png
Just FYI, Syykfk,
Please keep this question to just one per thread -- I saw you crossposted this question a few times with the same question.
I'm keeping this thread, it's useful to anyone diagnosing power management related issues (even though this topic is somewhat peripheral, various power mangement effects can create lag)
