Please help me solve the power management of the mouse "Allow the computer to turn off this device to save power" is gra
Syykfk
Post by Syykfk » 08 Aug 2023, 16:36
Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.
批注 2023-08-09 052834.png (74.8 KiB) Viewed 7258 times
F1zus
Re: Please help me solve the power management of the mouse "Allow the computer to turn off this device to save power" is
Post by F1zus » 08 Aug 2023, 17:31
So this setting is disabled through the registry or the mouse driver does not support power saving management.
All power saving options must be disabled, they affect mouse latency!
Syykfk
Post by Syykfk » 08 Aug 2023, 19:02
F1zus wrote:
08 Aug 2023, 17:31
How do I disable it via the registry? Thank you for your answer
eropsy
Post by eropsy » 09 Aug 2023, 04:59
Syykfk wrote:
08 Aug 2023, 16:36
Hey everyone, in the power management of my mouse, "Allow the computer to turn off this device to save power" is gray and cannot be checked, I tried many methods but could not solve it, do you have a way? Any answer will help me, thank you very much. I tried: reset bios, reinstall system, install latest chipset driver. None of them can be solved.批注 2023-08-09 052834.png
https://imgur.com/k4d2I6H Image
Everyone have like this by default, why you need to enable it?
Syykfk
Post by Syykfk » 09 Aug 2023, 10:26
eropsy wrote:
09 Aug 2023, 04:59
Syykfk wrote:
08 Aug 2023, 16:36
Does gray mean not enabled?
Syykfk
Post by Syykfk » 09 Aug 2023, 11:27
eropsy wrote:
09 Aug 2023, 04:59
Syykfk wrote:
08 Aug 2023, 16:36
Is this option grayed out for everyone?
eropsy
Post by eropsy » 09 Aug 2023, 11:59
Syykfk wrote:
09 Aug 2023, 11:27
eropsy wrote:
09 Aug 2023, 04:59
Syykfk wrote:
08 Aug 2023, 16:36
yes
eropsy
Post by eropsy » 09 Aug 2023, 12:07
Syykfk wrote:
09 Aug 2023, 10:26
eropsy wrote:
09 Aug 2023, 04:59
Syykfk wrote:
08 Aug 2023, 16:36
Image this is from "imprecise" guide, if you want to disable usb power savings
Syykfk
Post by Syykfk » 09 Aug 2023, 15:05
eropsy wrote:
09 Aug 2023, 11:59
Syykfk wrote:
09 Aug 2023, 11:27
eropsy wrote:
09 Aug 2023, 04:59
Syykfk wrote:
08 Aug 2023, 16:36
yes
Thank you for your answer, thank you very much!
Post by Chief Blur Buster » 09 Aug 2023, 20:16
Syykfk wrote:
08 Aug 2023, 16:36
Hi!
Just FYI, Syykfk,
Please keep this question to just one per thread -- I saw you crossposted this question a few times with the same question.
I'm keeping this thread, it's useful to anyone diagnosing power management related issues (even though this topic is somewhat peripheral, various power mangement effects can create lag)
