Ram causing desync/input lag
whatdahek
Re: Ram causing desync/input lag
Post by whatdahek » 31 Aug 2023, 13:14
By the way sometimes disabling spread spectrum works and sometimes it doesn't.
I can literally tell before I join the game by the feeling of my mouse if it's gonna be playable or not.
TheKelz
Post by TheKelz » 31 Aug 2023, 15:12
whatdahek wrote:
31 Aug 2023, 12:18
TheKelz wrote:
31 Aug 2023, 11:41
whatdahek wrote:
31 Aug 2023, 10:23
imprecise wrote:
31 Aug 2023, 05:25
There is a device in Windows:
Here's a short overview video on HPET. The speaker emphasizes Intel in the video but I know from experience AMD is just as bad or worse with this setting enabled, and AMD has acknowledged HPET decreases performance.
https://www.youtube.com/watch?v=IBsbAtchZcg
I've read the BIOS setting doesn't matter, but there may be a way to access hidden BIOS settings on your motherboard if you look it up.
I'll retry disabling hpet but it honestly makes no difference for me 99% of the time.
When the problem occurs the game even feels choppy, like it's stuttering.
I just don't get why it occurs randomly.
Some generic advices:
1. Uninstall Geforce Experience if you have it
2. If your monitor is FreeSync/Gsync, turn VSync on for games you play and limit 6 FPS lower than your refresh rate
3. Don't use RTSS as a frame limiter. Use something like Nvidia Frame Limiter instead
1. I don't have it.
2. Does not help/makes things worse.
Thank you tho, every idea helps.
What are your VCCIO and VCCSA voltages?
whatdahek
Post by whatdahek » 31 Aug 2023, 15:24
TheKelz wrote:
31 Aug 2023, 15:12
whatdahek wrote:
31 Aug 2023, 12:18
TheKelz wrote:
31 Aug 2023, 11:41
whatdahek wrote:
31 Aug 2023, 10:23
1. I don't have it.
I can't find these anywhere, do they have a different name for me ?
TheKelz
Post by TheKelz » 31 Aug 2023, 16:44
whatdahek wrote:
31 Aug 2023, 15:24
TheKelz wrote:
31 Aug 2023, 15:12
whatdahek wrote:
31 Aug 2023, 12:18
TheKelz wrote:
31 Aug 2023, 11:41
1. I don't have it.
Oh, wait, you have an AMD system. Didn't think that through. They're probably called something else in your BIOS, but at this point I don't even know if those voltages matter for you. For Intel, there are VCCIO (CPU Memory Controller) and VCCSA (System Agent) and their voltages need to be high enough depending on the sticks you have. Lower voltages can create instabilities, so I thought maybe there is something similar going on for you, but I'm not sure.
ptuga
Post by ptuga » 31 Aug 2023, 16:46
It does affect aim a bit but nothing major. Never had desync or anything like that unless it's unstable. If it's unstable it can feel like thrash, either cpu or ram.
On my current system. Jedec feels good, xmp (3200c14) feels worse, tuned feels best.
13700k
2x16gb 4200mhz 16-16-16 1.5v gear 1. tuned secondaries and tertiary timings.
whatdahek
Post by whatdahek » 31 Aug 2023, 16:58
ptuga wrote:
31 Aug 2023, 16:46
13700k
Pc can go from smooth and mouse light/precise to stuttery and mouse feeling heavy from a game to another it literally drives me crazy.
It's literally unplayable when the problem kicks in. And when everything is fine it feels like I'm smurfing.
whatdahek
Post by whatdahek » 31 Aug 2023, 17:10
TheKelz wrote:
31 Aug 2023, 16:44
whatdahek wrote:
31 Aug 2023, 15:24
TheKelz wrote:
31 Aug 2023, 15:12
whatdahek wrote:
31 Aug 2023, 12:18
1. I don't have it.
I'm sadly not familiar with bios opts, I don't touch ram/cpu voltages in bios so it's hard for me to fix it on my own if there is something related to that.
whatdahek
Post by whatdahek » 06 Sep 2023, 08:26
So after more experimenting I've fixed the input lag/heavy mouse issues by a lot.
I also ended up putting my cables/power strip higher than the floor on a wooden box and it also helped.
Don't know why but it did.
Now every time mouse becomes heavy I just move the power cables a bit and it gets fixed?
What could cause that and is there a way I can make it consistent and not have to move them around constantly ?
delve
Post by delve » 06 Sep 2023, 09:19
whatdahek wrote:
06 Sep 2023, 08:26
go to the emi section, it is clear you have it.
amorou
Post by amorou » 15 Nov 2023, 22:59
whatdahek wrote:
31 Aug 2023, 13:14
Yeap me too , same shit for years
