How to change bios hidden parameters (videoguide)
Re: How to change bios hidden parameters (videoguide)
Post by Slender » 26 Jan 2025, 03:53
SeekNDstroy wrote: ↑
25 Jan 2025, 06:48
Slender wrote: ↑
24 Jan 2025, 18:37
Kentar wrote: ↑
22 Jan 2025, 19:27
What is grub? I didn't see it on the video.
use scewin, that new and simplest
Do you know/ have any idea if i use grub, and then try to scewin, will it work?
For some reason, my system freezes if i use the export cmd (with enablelua fix). So i had to use the grub.
However, recently i found that, instead of writing "export", if i copy-paste the full command inside of the command file, it works. Nice! Problem solved. Then i changed a few one & try to import. But it always says fail. Even without modifying anything, just export & import also fails.
As grub takes more time & precision, im not willing to flash a fresh bios just to check the scewin at the moment. I may do that later when i will get extra time. I need to be sure that scewin must require a fresh unmodified bios to work or not.
scewin need run some chipset driver running.
whats your cpu?
try to disable / enable secure boot.
https://winraid.level1techs.com/t/guide ... ings/94069
rooy
Post by rooy » 26 Jan 2025, 14:12
did u know if it works on asus rog strix z270f with 7700k cpu ?
Post by Slender » 27 Jan 2025, 11:21
rooy wrote: ↑
26 Jan 2025, 14:12
scewin? yes.
if not export/import try to install / reinstall chipset drivers or factory bios.
SeekNDstroy
Post by SeekNDstroy » 28 Jan 2025, 05:16
Slender wrote: ↑
26 Jan 2025, 03:53
25 Jan 2025, 06:48
Slender wrote: ↑
24 Jan 2025, 18:37
Kentar wrote: ↑
22 Jan 2025, 19:27
whats your cpu?
i5-11400 with B560m Aorus Elite. I had secure boot disabled. Tried enabled & disabled. Now the export is not working even with the line. I didn't install any chipset driver, as that feels better for me. I will try with fresh bios later. Thanks
JimCarry
Post by JimCarry » 28 Jan 2025, 08:19
Slender wrote: ↑
27 Jan 2025, 11:21
rooy wrote: ↑
26 Jan 2025, 14:12
scewin? yes.
Thanks i just did uninstall my chipset drivers, restart pc then try scewin(i have 2 versions of scewin-new one and older one), again it works it exports but it does not show all settings it show only some sh@t ones,the only thing that i did not try is fresh bios i will try that soon,thanks anyway big man.
Post by Slender » 28 Jan 2025, 16:21
JimCarry wrote: ↑
28 Jan 2025, 08:19
Slender wrote: ↑
27 Jan 2025, 11:21
rooy wrote: ↑
26 Jan 2025, 14:12
scewin? yes.
scewin .log
JimCarry
Post by JimCarry » 28 Jan 2025, 16:51
Slender wrote: ↑
28 Jan 2025, 16:21
JimCarry wrote: ↑
28 Jan 2025, 08:19
Slender wrote: ↑
27 Jan 2025, 11:21
rooy wrote: ↑
26 Jan 2025, 14:12
scewin? yes.
scewin .log
I dont really understand you ?
Post by Slender » 28 Jan 2025, 16:52
JimCarry wrote: ↑
28 Jan 2025, 16:51
Slender wrote: ↑
28 Jan 2025, 16:21
JimCarry wrote: ↑
28 Jan 2025, 08:19
Slender wrote: ↑
27 Jan 2025, 11:21
scewin? yes.
scewin .log
send me your scewin logfile where export / import info
JimCarry
Post by JimCarry » 28 Jan 2025, 16:55
Slender wrote: ↑
28 Jan 2025, 16:52
JimCarry wrote: ↑
28 Jan 2025, 16:51
Slender wrote: ↑
28 Jan 2025, 16:21
JimCarry wrote: ↑
28 Jan 2025, 08:19
scewin .log
this is the log file,wich one do you want nv ram or i can upload "Bios settings" with the old version of scewin?
