Everything about latency. This section is mainly user/consumer discussion. (Peer-reviewed scientific discussion should go in Laboratory section). Tips, mouse lag, display lag, game engine lag, network lag, whole input lag chain, VSYNC OFF vs VSYNC ON, and more!
Input Lag Articles on Blur Busters.
Fpsgamer
Post
by Fpsgamer » 09 Aug 2025, 07:14
unconnected wrote: ↑03 Aug 2025, 17:54
Fpsgamer wrote: ↑03 Aug 2025, 15:12
unconnected wrote: ↑03 Aug 2025, 13:05
Fpsgamer wrote: ↑02 Aug 2025, 03:28
Actually managed to fix it by a lot by lowering my isr.
I had like 2k interrupts per second with only discord open and dropped it to like 50-100 per sec.
There are still occasional stutters which seem to be connected to 1% lows, shouldn't happen but will most likely find a solution to that aswell soon.
How did you manage to lower them so much?
I changed all my usbs to the cpu ports instead of chipset. Headset and mic were causing issues
Would you please post a report from latencymon of before and after the change? Might be a confirming factor for others to try and investigate further
- 2.png (5.92 KiB) Viewed 576 times
- 3.png (5.54 KiB) Viewed 576 times
Here are before/after pictures
