Page 126 of 153
Posted: 04 Aug 2026, 03:35
by BLooDS_inc
Tell wrote: ↑01 Aug 2026, 16:52
Are you guys seeing a bug with pulsar and vsync enabled causing much higher pc latency as reported by the nvidia overlay? For example vsync on with reflex caps to 320fps and the average pc latency bugs out and starts getting stuck at 12-14ms. Disabling vsync and setting in game fps cap to the same 320fps results in around 4.5ms average pc latency.
Is my monitor defective? Im using the acer version with the latest firmware, just asking in here since its by far the most popular thread.
edit; same experience someone had here with the asus version five months ago...
https://www.reddit.com/r/Monitors/comme ... ks_fps_to/
If u use the vsync , for lowest possible latency u need to use vsync+gsync+reflex on ultra, and u will get the lowest possible latency with vsync, but i don't like it, using only rivatuner cap around 327fps(frame start presentation+front edge sync cap) with reflex only ON and gsync on give me the best framepace and best fps consistency if u wanna slightly better lower latency so u can raise cap to 342 fps
liquidshadowfox wrote: ↑01 Aug 2026, 19:51
Does anyone here have the Acer model? I have a few friends who bought the acer model and one of them received their monitor today, did the firmware update and Gsync pulsar had some weird inverse ghosting artifacts and some other issues with ULMB 2 mode. Currently asked them to do a DDU driver wipe and reflash the firmware to latest to see if it fixes it but I'm curious to see if anyone else is having this issue on latest 1.1.8 firmware on acer. Also WOW acer's menus are a lot less intuitive than Asus and it's really hard to help anyone troubleshoot settings... can't even see what version of firmware you are on the acer one.
I have the msi version of the monitor, have latest Nvidia drivers, have latest FW, playing with rivatuner 327 cap+ gsync on+reflex only on+pulsar on.
I don't know what's going on here, BUT, sometimes, when i playing pubg, my friend driving a car and I'm looking around from a fast moving car all around smooth and clear and sometimes my weapon with scope get some shit ghosting when I'm wiggling left right. Idk why and when this going on, but this going only when u fast moving and u start wiggling left right, my scope start bad ghosting like a hell
Posted: 04 Aug 2026, 08:26
by tsarri
Tell wrote: ↑03 Aug 2026, 13:36
liquidshadowfox wrote: ↑03 Aug 2026, 13:09
Right now on woot the acer Gsync pulsar monitor is going for like $380 so it's an absolute steal lol
I purchased the Acer pulsar at this price and already returned it. The 320fps bug with vsync is still alive after six months with no word from Nvidia about working on the fix. The IPS glow was the worst I have seen, possibly defective levels. The viewing angles were so bad that if you were sitting dead center of the monitor the system time on the bottom right of the screen was blurred or washed out, moving your head to the right cleared it up. My previous IPS monitors never looked this bad.
After having both on the desk I have gone back to the Acer 500hz oled that was $500 last month. It has usable HDR with amazing blacks and viewing angles. The pulsar monitor wins for motion clarity but the 500hz oled isn't that far behind in my opinion.
First time hearing about this bug. When it comes to the quality of the panel it should be clear to everyone by now that this is a below average IPS panel in every regard except motion handling and brightness. Contrast, viewing angles and backlight bleed are below average for modern IPS panels. Even when compared side by side with the PG27AQN (similar retail price) this panel is noticeably worse in those aspects, never mind when compared to an OLED its not even close.
Posted: 05 Aug 2026, 08:50
by mawi
Has anyone of you found a good setting for playing C&C remastered? No matter what I try... pulsar or ULMB, framecap (internally or via rtss), vsync, gsync on/off. It looks like sh*t... I mean, 120 fps ulmb with the latest firmware should be clear and smooth af...
I mean, I guess I now why... Steam overlay shows the low fps which are always very low compared to average. But when I have an average of 320 with lows around 160, why cant the game keep 120 straight for ulmb? When setting the target fps ingame to 120, the game seems to double it. steam overlay shows sth around 235. Of course with really bad lows.
with my hardware it should easily be possiblt to run this game on straight 120 fps. no dips, nothing.
I just dont get it. This should be a game which has the "wow" scrolling like the Anno game in the pulsar presentation videos. But its just really bad... By bad I mean, it looks like on "normal" displays.
Posted: 05 Aug 2026, 10:27
by BLooDS_inc
mawi wrote: ↑05 Aug 2026, 08:50
If your fps doubled, it's can be the smooth motion in Nvidia app, try to turn it off
Posted: 06 Aug 2026, 07:01
by daviddave1
x
Posted: 06 Aug 2026, 08:39
by mawi
BLooDS_inc wrote: ↑05 Aug 2026, 10:27
Thanks for the hint, but smooth motion is "not supported" on C&C remastered according to the Nvidia App.
I have the feeling this is because the game is not actually a 3d game and its very close connected to the old engine (you can swap the new textures and retro style on the fly). The sidescrolling seems to be somehow in fix jump distances. The picture is sharp. nothing is blurry but its just not fluent and clear.
Posted: 06 Aug 2026, 17:26
by BLooDS_inc
Msi monitor, Latest Nvidia drivers, Latest 1.1.8 FW, Pulsar ON, Gsync On, reflex ON, Vsync OFF, gaming Pubg with 327fps cap via rivatuner front edge sync and frame start presentation, if u fast moving ingame and wiggling here and there with your camera u can see a double imaging start ( even when my fps consistent 327 and not drops ). Here i provide the screenshots when my fps stays 327 and i have double imaging with Pulsar ON
Posted: 06 Aug 2026, 21:57
by liquidshadowfox
BLooDS_inc wrote: ↑06 Aug 2026, 17:26
Put in a bug report to nvidia so they can look at it themselves and see if they can replicate the issue.
Posted: 06 Aug 2026, 23:16
by bbxcearty
Looks like AA issue to me, isn't it?
Posted: 07 Aug 2026, 08:54
by kyube
New data as of today
Link:
https://www.nvidia.com/en-us/geforce/fo ... opicPage=3
Nvidia has finalized the table of how ULMB2 @ 240Hz is.... and I'm already disappointed with the targetted pulse on time @ 120cd/m²...
Let's hope that 360Hz slope will be more aggressive...
Here's the interpolated slope behavior of how each
Pulse Width setting scales in terms of
Effective Motion Clarity (Nvidia term for the inverse of pulse on time AKA frequency-domain value of pulse-on time):
Notice how
120 Hz (8,333 ms) @ PW=25 (0,65 ms) @ 120 cd/m² has a
SHORTER pulse on time than
240 Hz (4,1667 ms) @ PW=25 (0,83 ms) @ 120 cd/m²
This means that, if the claim of 1800–2000 cd/m² voltage boosting behavior is true:
PW=25 @ 120 Hz targets a ~7,8% pulse width
To be able to hit that at 120 cd/m², this implies a 1538 cd/m² voltage boosting behavior (which is roughly in-line with reported data from users here)
PW=25 @ 240 Hz targets a ~19,9199% pulse width
602,409 cd/m² voltage boosting behavior
Why is there such a large negative discrepancy between 120Hz & 240Hz in terms of voltage boosting?
I don't know... This is ULMB1 levels of voltage boosting, akin to the PG259QN & S2417DG... Very mediocre target...
This implies that Nvidia is still being tame in pushing lower duty cycle targets on the 240Hz & 360Hz refresh rate settings.
Much performance is left under the table...
This implies that, on PW=10:
https://testufo.com/ghosting#pps=1440 would be 1px of blur
https://testufo.com/ghosting#pps=2880 would be 2px of blur
Which already invalidates it from competing with a CRT, like other models within the same category (QHD 240–360 Hz)
Don't forget that CRTs can do +3000 px/s with ≤1px of blur, which is the benchmark for any backlight strobing implementation on the market
