do you try disable mmcss service ?
No FPS gaming possible
LaggyTyp
Re: No FPS gaming possible
I'm noticing something strange.
After I had everything set up and it was running really well, I started the "TimerTool" and saw that it automatically set itself to 1ms. It's been running like this for 2-3 days now (even after a restart).
I just wanted to play a round, and it's running poorly again. According to "TimerTool," I'm back at 15.625ms, even though I haven't changed anything.
Does anyone have an explanation?
I never set anything. It automatically set itself to 1ms.
- Slender
Windows Registry Editor Version 5.00LaggyTyp wrote: ↑06 Aug 2025, 12:23I'm noticing something strange.
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\kernel]
"GlobalTimerResolutionRequests"=dword:00000001
why u ignore me?
LaggyTyp
The game is fully desynced, but I don't die that quickly.
bcdedit /set disabledynamictick no
The game is synced, but I die extremely quickly.
Whoever solves this puzzle gets an Oscar from me.
dermodemon
delete all your tick and platformclock values from bcdedit /enum
disable every offload possible in your nic settings
disable flow control in your nic settings
disable interrupt moderation in your nic settings
set your Buffering to smooth over packet loss in cs2 to NONE
type cl_interp_ratio 2 in cs2 console and play.
post the results later please
p.s. i found something weird. After i disabled above 4g decoding and rebar in bios, i have much smoother and enjoyable frames
LaggyTyp
Thanks!
I'm playing Battlefield 2042 + 6 (starting tomorrow).
Right now, I'm experiencing massive desync.
I'm hitting enemies, but they just don't fall over. It takes 2-3 seconds to take someone down.
I don't understand it.
LaggyTyp
bcdedit /deletevalue disabledynamictick
bcdedit /deletevalue tscsyncpolicy
bcdedit /deletevalue useplatformclock
bcdedit /deletevalue useplatformtick
I can't play at all anymore. It's impossible.
- kriegsnake
Play with whatever settings that you have better hitreg, but at the end of the month you will delete all of these settings , because there is no magic enable button.
LaggyTyp
I can't rule out the possibility that it's a local issue. Something caused by my motherboard (Z690), for example.
Does anyone know this option? What does it do? Turn it on? Turn it off?
BCLK TSC HW FIXUP
BCLK TSC HW FIXUP
LaggyTyp
I suspect that in my case it is the timers (TSC / RTC) that are causing Desnyc.
Even though my BLCK is 100, the CPU clocks 0.0012Mhz higher than desired.
