Page 3 of 3
Re: Finally discovered the source of my unexplicable problems [WITH IMAGES]
Posted: 14 Jul 2024, 10:20
by Tuhin Lavania
You mentioned enemies were prefiring you and you had no reaction time ? That problem has solved now ?
Posted: 14 Jul 2024, 16:19
by stormdak1ng
Tuhin Lavania wrote:
14 Jul 2024, 10:20
Yes, before all competitive games was simply unplayable
Posted: 14 Jul 2024, 22:32
by Tuhin Lavania
stormdak1ng wrote:
14 Jul 2024, 16:19
14 Jul 2024, 10:20
Thats insane. I will have to look into this as im facing the same problem since years now. Nothing helped. Changed isps, hardware, nothing helps. Electricity is the last thing i think about.
Posted: 25 Jul 2024, 03:10
by Fishie
Hello, Is this still fixed for you? Please be honest. We (and probably you) have been stuck with this issue for years and are going crazy with no solution :cry:
Posted: 27 Jul 2024, 17:12
by stormdak1ng
Fishie wrote:
25 Jul 2024, 03:10
Yes, in my case, that fixed all my issues. Probably this is not the problem of 99% of u guys, i'm just shared my history and maybe could help someone.
