Stevie66
Post by Stevie66 » 03 Feb 2021, 21:58
Discorz wrote: ↑
03 Feb 2021, 04:06
Btw, is that 60Hz input lag present on every firmware version (MCM103/104/105)?
It will always have high input lag when you manually set your hz to 60.
Discorz
VIP Member
Post by Discorz » 04 Feb 2021, 06:08
Stevie66 wrote: ↑
03 Feb 2021, 21:58
Do you own this monitor? What about refresh rates set above 60Hz; 75, 85 or 100Hz? At what point does it stop?
Stevie66
Post by Stevie66 » 04 Feb 2021, 07:17
Discorz wrote: ↑
04 Feb 2021, 06:08
Stevie66 wrote: ↑
03 Feb 2021, 21:58
I own this monitor, no idea as I don't see a point ever setting it at any of those refresh rates. Consoles are 60hz, old school games on PC are 60hz, pretty much everything else you'll have at 280 or 240.
lowfiguy7
Post by lowfiguy7 » 05 Feb 2021, 20:51
Is the asus worth getting over the BenQ Zowie XL2540K ?
DukeDice929
Post by DukeDice929 » 06 Feb 2021, 11:26
lowfiguy7 wrote: ↑
05 Feb 2021, 20:51
It's worth if you gonna use it for more than just gaming: content creation, photoshop, movies etc. Better colors and viewing angles on IPS panels do the work.
My bad English :0
PixelDuck87
Post by PixelDuck87 » 07 Feb 2021, 14:00
lowfiguy7 wrote: ↑
05 Feb 2021, 20:51
I moved to asus from xl2411z. I'd say Benq TNs for gaming are still KING.
Discorz
VIP Member
Post by Discorz » 08 Feb 2021, 03:30
lowfiguy7 wrote: ↑
05 Feb 2021, 20:51
I haven't used any Zowie monitor and came to conclusion that the only thing that Zowie is good at is DYAC+/backlight strobing, for anything else it's not worth getting. So if you need best strobing get CRT, if u need slim CRT get Zowie haha :D
Discorz
VIP Member
Post by Discorz » 08 Feb 2021, 03:40
Stevie66 wrote: ↑
03 Feb 2021, 21:58
My VG279QM arrived and it doesn't have such issue (firmware MCM103), but its still definitely slower than my other 60Hz monitors.
Some reviewers reported around 35ms of lag, mine is at least half of that.
Stevie66
Post by Stevie66 » 08 Feb 2021, 17:30
Discorz wrote: ↑
08 Feb 2021, 03:40
Stevie66 wrote: ↑
03 Feb 2021, 21:58
What device did you use to test your input lag?
Discorz
VIP Member
Post by Discorz » 08 Feb 2021, 17:54
Stevie66 wrote: ↑
08 Feb 2021, 17:30
I did not use any device. It's very noticeable in this video, based on that I concluded its not that high.
https://youtu.be/xGluvAAE5RU?t=541
