ZOWIE XL2566K Discussion Thread [24.5" 360hz TN]
Falkentyne
Re: ZOWIE XL2566K Discussion Thread [24.5" 360hz TN]
Post by Falkentyne » 20 Oct 2022, 18:14
Anyone try 60hz strobing on this yet? :(
Post by Slender » 21 Oct 2022, 04:18
I'll get my copy soon, what tests should I do?
Post by Chief Blur Buster » 21 Oct 2022, 06:10
Falkentyne wrote: ↑
20 Oct 2022, 18:14
It's almost guaranteed to be 100Hz min-frequency strobe, but please let me know if anyone is able to pull off lower-Hz strobe.
Post by Chief Blur Buster » 21 Oct 2022, 06:12
kyube wrote: ↑
20 Oct 2022, 12:13
Crosstalk tests are here! (disclaimer: panel hasn't warmed up yet) Source: Zace from r/monitors discord
Discorz wrote: ↑
20 Oct 2022, 13:00
Oh great! Thanks for forwarding.
I think top one is 240 and bottom one is 360 Hz. Higher refresh rate always has narrower spacing between frames assuming both are taken at same speed. And GtG proportion is better at 240 Hz.
Also for stationary-camera smartphone photo, make sure smartphone shutter is at least 2x faster than refresh cycle. This minimizes chances of accidentally capturing two strobe into the same camera exposure.
Sometimes you have to download the ProCam or DSLRCamera app to do this, to force fast shutter speed.
Discorz
VIP Member
Post by Discorz » 21 Oct 2022, 07:23
21 Oct 2022, 06:12
I think its pursuit camera because frame is blurred on 360 Hz shot. Can be hard to judge sometimes. Pls add Sync Track to full screen strobe crosstalk test.
Those apps can be weird. I've tried dozens of them. While they provide more flexible shutter, other basic settings are lost.
Post by Chief Blur Buster » 21 Oct 2022, 07:54
Discorz wrote: ↑
21 Oct 2022, 07:23
Doesn't seem like it.
Reduced size thumbnails just make it look blurry.
You have to zoom to original size.
It looks like multiple exposures, like camera shutter too slow for refresh cycle. Need camera shutter that's no slower than 1/360sec.
See zoomed crop of the earlier attached image:
I know XL2566K does better than that.
I hereby invalidate those reddit photographs as worse-than-actual-XL2566K
Discorz
VIP Member
Post by Discorz » 21 Oct 2022, 08:41
21 Oct 2022, 07:54
Discorz wrote: ↑
21 Oct 2022, 07:23
Thats probably 240 Hz you cropped.
I meant the monitor frame.
https://i.ibb.co/LJL6FWv/XL2566-K-Dy-Ac ... mid-up.jpg
kyube
Post by kyube » 21 Oct 2022, 14:33
New shots have arrived! Source: DCBF_GGoki from r/monitors discord
360hz sample and hold performance on different OD levels:
21 Oct 2022, 06:10
Falkentyne wrote: ↑
20 Oct 2022, 18:14
It does seem like you are correct, according to this:
Perhaps there are some DDC/CI commands that are able to be used by the Blurbusters utility to adjust strobing? How would one look for these?
Post by Chief Blur Buster » 21 Oct 2022, 17:46
kyube wrote: ↑
21 Oct 2022, 14:33
Try hitting "F" after launching Strobe Utility and using profile A and B, to see if either work.
Failing that, edit BlurBustersStrobeUtility.ini configuration file to find XL2566K DCC's
kyube
Post by kyube » 21 Oct 2022, 19:50
Service menu pictured, picture made by @DCBF_ggoki
You enter the menu by pressing the joystick button with power button (while the monitor is turned off)
21 Oct 2022, 17:46
kyube wrote: ↑
21 Oct 2022, 14:33
The XL2566K is confirmed working with the Blurbusters utility!
2.09 version
