BenQ XL2540K or Asus VG258QM
Re: BenQ XL2540K or Asus VG258QM
does somebody have early access ? https://www.rtings.com/monitor/reviews/ ... ng-vg258qm
sure. Don't Know if can I share it.
The monitor is 10bit with contrast of 1107 : 1 and 424 cd/m² SDR Peak Brightness.
Bad viewing angle like other TN.
Best Overdrive Setting 280Hz
Level 3
Rise / Fall Time
2.9 ms
Total Response Time
7.5 ms
Overshoot Error
4.8 %
Dark Rise / Fall Time
1.5 ms
Dark Total Response Time
4.6 ms
Dark Overshoot Error
7.8 %
Input Lag
Native Resolution
2.4 ms
Native Resolution @ 60Hz
34.7 ms
Variable Refresh Rate
2.6 ms
Variable Refresh Rate @ 60Hz
39.9 ms
10 Bit HDR
4.1 ms
Black Frame Insertion (BFI)
4.7 ms
I will receive mine tomorrow, so I can test it
Yes I do, what would u like to see?
Ty !) Input lag looks like should be higher than on mine vg279qm, it sad news.ezbill wrote: ↑25 Mar 2021, 01:55sure. Don't Know if can I share it.
Level 3
Rise / Fall Time
2.9 ms
Total Response Time
7.5 ms
Overshoot Error
4.8 %
1.5 ms
4.6 ms
7.8 %
Input Lag
Native Resolution
2.4 ms
34.7 ms
2.6 ms
39.9 ms
10 Bit HDR
4.1 ms
4.7 ms
I will receive mine tomorrow, so I can test it![]()
yes, seems not that great, tomorrow I will test it. Do you want to see something in particular?sk1p wrote: ↑25 Mar 2021, 10:07Ty !) Input lag looks like should be higher than on mine vg279qm, it sad news.ezbill wrote: ↑25 Mar 2021, 01:55sure. Don't Know if can I share it.
Level 3
Rise / Fall Time
2.9 ms
Total Response Time
7.5 ms
Overshoot Error
4.8 %
1.5 ms
4.6 ms
7.8 %
Input Lag
Native Resolution
2.4 ms
34.7 ms
2.6 ms
39.9 ms
10 Bit HDR
4.1 ms
4.7 ms
Hey, could one of you post response time results for overdrive Level 4 and Level 5 please?
Not available at the moment. The ELMB Sync seems to be much better implemented than vg259/79qm.
I see, thanks anyway
No double pulse strobe when using ELMB-Sync?
If they actually got it right with the VG258QM it will be the first monitor they released with properly functioning ELMB-Sync (not to be confused with standard ELMB since it works correctly in every single Asus monitor).
*= currently owned
CPU: 5800x3d 102mhz BCLK
GPU: 3080FE undervolted
MOUSE: Endgame Gear OP1 8k
KEYBOARD: Wooting 60he
*= currently owned
