DukeDice929
Post by DukeDice929 » 24 Feb 2021, 19:07
quorrA wrote:
24 Feb 2021, 11:38
Hi guys, I have a problem with vg259qm.
My windows display settings showing 279.857hz.
and when I look at settings with cru, I see it is different from the default settings shared on the forum
Nothing wrong, because it's a stock "280Hz" refresh rate and timings.
And yes, refresh rate placement in CRU become a bit different when overclocking enabled. That's what could have confused you.
My settings are the same as yours, so don't worry about it. ;) https://i.ibb.co/9w3NYYS/280-Hz-stock.png
My bad English :0
quorrA
Post by quorrA » 24 Feb 2021, 19:14
DukeDice929 wrote:
24 Feb 2021, 19:07
quorrA wrote:
24 Feb 2021, 11:38
Ah i understand now. Thank you, I am relieved
Anthonynuzzo
Post by Anthonynuzzo » 27 Feb 2021, 12:15
What would be the best settings for me to use if i main valorant? looking for lowest input lag so my shots can register before enemies if possible my rig consists of i7 10700k and a 2080
jazurm1337
Post by jazurm1337 » 27 Feb 2021, 12:49
Anyone know the input lag for the VG259QM at 120hz? I'm using this monitor for both PC and Xbox Series X gaming. I have my Xbox set to output 120hz and I haven't seen any information about input lag at 120hz.
r0fless
Post by r0fless » 27 Feb 2021, 21:24
Hi, since scrambling through this big of a thread is not my strongest point, any simple answer with monitor settings for VG259QM that is best for the lowest input lag? Think I have gotten some stuff into my head from reading but want to ask myself. My main games are CS and Battlefront. Should Adaptive-sync be disabled or enabled? Overdrive 60 or 80? Is 240 better than 280 for the lowest input lag? Does ELMB sync have any befits for FPS-games? (worth using?) Any tips are appreciated. Got this monitor in today. :D
Language
Post by Language » 05 Mar 2021, 04:05
Can anybody help me? If i play in CS:GO with 1280x960 resolution i should add in CRU 2 resolutions with fixed hertz for no drops 280 to 144? 1920x1080 and 1280x960? Or just 1920x1080? Thank you
Darkvader100
Post by Darkvader100 » 05 Mar 2021, 07:45
Hi, if i overclock the monitor to 280hz, how will the input lag be if the game has a lot of fps drops (fortnite)? Since the monitor have high input lag on 60hz. I got a rtx 3080 and i7 10700k.
Discorz
VIP Member
Post by Discorz » 05 Mar 2021, 17:39
r0fless wrote:
27 Feb 2021, 21:24
For lowest input lag use highest refresh rate, adaptive sync and ELMB disabled (unnoticeable difference).
For 200-280 fps use OD80, below 200 OD60 or lower.
Uncap fps in game, fullscreen mode, keep gpu load below 95%.
Some mice have lower latency with higher DPI.
Test ELMB/SYNC yourself and see if it has any benefits. :)
Discorz
VIP Member
Post by Discorz » 05 Mar 2021, 18:09
jazurm1337 wrote:
27 Feb 2021, 12:49
You can do some calculations from this
viewtopic.php?p=63624#p63624
Stevie66
Post by Stevie66 » 06 Mar 2021, 09:35
Do you think running the monitor at 240hz instead of 280hz would prolong the life of the monitor seeing how 280hz is an "oc"?
