Turn off all the circuit breakers in the electrical panel and leave only the one for your room onYazeedtt wrote: β03 May 2026, 19:45https://imgur.com/a/r9WsQiU
Is it possible that this damaged outlet attached to the electricity meter is the cause of the problem? I donβt even know why it is there in the first place like this.
ELECTRICITY INPUT LAG.. HOW I FIXED IT?!
1nputlag34
Re: ELECTRICITY INPUT LAG.. HOW I FIXED IT?!
jterri
Have you tested this? How did it feel?1nputlag34 wrote: β04 May 2026, 07:06Turn off all the circuit breakers in the electrical panel and leave only the one for your room onYazeedtt wrote: β03 May 2026, 19:45https://imgur.com/a/r9WsQiU
1nputlag34
No change for me this helps you determine if a device in your home is causing the problemjterri wrote: β10 Sep 2026, 03:18Have you tested this? How did it feel?1nputlag34 wrote: β04 May 2026, 07:06Turn off all the circuit breakers in the electrical panel and leave only the one for your room onYazeedtt wrote: β03 May 2026, 19:45https://imgur.com/a/r9WsQiU
unexpected8
astroasis
You guys sure its not 2.4ghz signals? mine returned at my new house then i remembered i turned wifi on, its fine now with it off. Ethernet transmitting emi is fake news
MK92
And what would wifi signal do to a PC? In theory a 2.4 ghz wifi signal could cause interference with a wireless mouse only, but if you have wired stuff its completely irrelevant and harmless
jterri
What do you think is causing the interference in your opinion?1nputlag34 wrote: β10 Sep 2026, 06:48No change for me this helps you determine if a device in your home is causing the problemjterri wrote: β10 Sep 2026, 03:18Have you tested this? How did it feel?1nputlag34 wrote: β04 May 2026, 07:06Turn off all the circuit breakers in the electrical panel and leave only the one for your room onYazeedtt wrote: β03 May 2026, 19:45https://imgur.com/a/r9WsQiU
