mawi
Post by mawi » 20 Apr 2026, 12:54
BLooDS_inc wrote: ↑
20 Apr 2026, 10:23
and i find another bug with pulsar, when u go into full sleep , when power indicator goes from white to orange, after sleep is off, the pulsar always turns off, trying this several times and this goes all the time.
Already 2 bugs on MSI's version - pulsar goes off after sleep mode and unenable pulse width setting for 60hz ULMB
That is not MSI exclusive. I have the same thing with the ASUS model. I mentioned this some weeks ago. Whenever it goes to sleep for more than just a few minutes and i come back, its just ULMB2. And I cannot change this by software, not by OSD and not by nvcp like switching gsync off and back on.... it remains ULMB2 on osd. Which is weird because how would a ULMB2 mode look like with gsync turned on?!
The only thing getting pulsar back is restarting the display or rebooting windows. Annoying, but for me this has the lowest priority to be fixed :)
BLooDS_inc
Post by BLooDS_inc » 20 Apr 2026, 13:31
mawi wrote: ↑
20 Apr 2026, 12:54
BLooDS_inc wrote: ↑
20 Apr 2026, 10:23
Im just turn pulsar again in osd
Lunatic
Post by Lunatic » 20 Apr 2026, 19:08
Hi there!
I recently bought the Acer Predator XB273U F5 (immediately updated to firmware version 1.1.4) and although I’m generally very happy with it and the motion clarity it provides, I wanted to share some feedback: viewtopic.php?p=124317
edgintheledge
Post by edgintheledge » 20 Apr 2026, 19:17
ManuelG_NVIDIA wrote: ↑
20 Apr 2026, 03:30
-Regarding the double image behavior observed on G-SYNC Pulsar displays when operating within the 100–180 FPS range, a fix has been implemented and will be included in an upcoming G-SYNC Pulsar firmware update version 1.1.6.
Well now that we know there's another update coming these pursuits might be redundant but I'll leave them here anyways. Though I wonder if this means this range will look even better than what I photographed here? 👀👀👀
Things to know about these shots
  • This is 180fps capped only ingame (Engine is unreal 5 if it matters)
  • 1/45sec shutter used
  • My phone was held vertically during these shots, unsure if relevant but this changes the orientation of rolling shutter to be horizontal across the screen instead of vertical.
  • Without a sync track the best verification I can do is with the grid of stationary lines in the background. The vertical lines are only single lines, but each subsequent strobe captured in the 1/45sec window creates that grouping of 3. The consistent spacing suggests good horizontal tracking (I thought it would be groupings of 4 since 180/4=45? Maybe that logic is for testufo which isn't vrr or smoothfrog which doesn't have frametime inconsistencies that an actual game can? Or my phone is lying about the shutter speed).
  • The character runs across the monitor in ~0.9 seconds timed with a stopwatch including initial dash (Characters don't instantly run full speed in this game) this means the pursuit speed is around 3000px/sec in these photos depending on how accurate my stopwatch timing was and initial dash speed/accel ingame.
  • Unlike many fighting games, the character animations in this game are decoupled from the game's 60hz logic and interpolated to the framerate. 1/45sec shutter is capturing multiple screen refreshes/frames of 180 fps animation causing image duplication-esque effects in some photos. The text above the character moves horizontally more like a smoothfrog test scenario and is more indicative of what I see.
I have attached a shot where the strobe looked best with basically no preceeding image, one where a faint vertical line in the background might be a compensation pulse captured, and one where the preceeding image was most noticeable. I don't think I'm seeing the same strobe behavior as Mawi and Brownvim have mentioned.
clearest pursuit downsized.jpg (128.37 KiB) Viewed 1430 times
compensation pulse maybe downsized.jpg (133.16 KiB) Viewed 1430 times
OK pursuit downsized.jpg (122.98 KiB) Viewed 1430 times
brownvim
Post by brownvim » 21 Apr 2026, 01:25
You can recreate the ghosting behaviour doing the below, this is what I posted for Nvidia to recreate it, realised I didnt post it on this forum.
I tried recording the issue in RE9 but it's almost impossible to capture properly on video.
Instead, I recreated the exact ghosting behaviour using SmoothFrog v0.5p (simple UI version here):
https://www.aperturegrille.com/software ... it0.5p.zip
How to test it:
1. Open the program and press F to bring up the long FPS slider.
2. Gently wobble the slider left and right to simulate fluctuating frame rates (like real VRR behaviour).
On the new firmware ~180 FPS to 360 FPS it stays perfectly clean with no ghosting. However, once I drop it to around 120 FPS (or let it fluctuate in that range), I immediately see a sharp ghosted/double image for a short period as soon as the frame rate gets adjusted with the slider.
Before the new firmware: Ghosting only appeared at 90 FPS and below. The 90–360 FPS range was clean.
After the new firmware: Ghosting now starts appearing from around 90-180 FPS.
Maybe its harder to tell in shooters? I don't really play them. In games I play its noticeable. Its not like a contant ghosted image, more like when frame rate shifts up and down. I dont think the compensation pulse should cause a ghosted image either? its just so we dont perceive flicker right?
mawi
Post by mawi » 21 Apr 2026, 04:42
brownvim wrote: ↑
21 Apr 2026, 01:25
To me this "ghost" image on RE9 also felt like it has a different color... some kind of purple side ghost of the actual image. I dont know if this is just some kind of human eye thing or if this can really be captured by a camera. Especially in the bright white hallway of RE9 this is very noticable.
This was different on the old firmware below 90 fps with the double imaging which was introduced due to double Hz (OSD showed 180 Hz when game had 90 fps etc). And as mentioned, no ghosting at all above 90 fps.
This is not the case here now. Its some kind of ghosting with 100-160fps internally and the same Hz on OSD. No double hz etc.
edgintheledge
Post by edgintheledge » 21 Apr 2026, 05:55
brownvim wrote: ↑
21 Apr 2026, 01:25
I see what you mean now cause I can recreate that same behavior in smoothfrog. Maybe I just got lucky that my ingame framerate is stable enough to not trigger the issue, but it definitely isn't external framecap stable. When I ingame capped to 180, my avg is 180 and my 0.1% low is 142.
In shooters it probably depends more on if you fix your gaze on a crosshair (stroboscopic/hz limited) vs eyetrack a target (persistence limited). The game I took pursuits of is a 2.5D platform fighter so there is alot of fast eyetracked scenarios.
As for the compensation pulse, I thought it was to mitigate how noticeable changing the strobe persistence is at the cost of introducing some extra double image looking artifacts, and that the monitor weakens this pulse as framerate stabilizes. Someone more knowledgeable can correct me here but I don't believe there's anyway to not introduce double imaging artifacts by pulsing more than once per frame since your eyes will continue smooth tracking and place the extra pulse of the same frame in a slightly different place in your vision.
How I understand the compensation pulse behavior appears to line up with what I captured in the one photo. There's one extra strobe that was weaker indicated by the faint 4th line while every other group of lines only has 3. My phone's shutter was rolling horizontally across the screen during the photo, so that could explain why it showed up that way in the photo.
mawi wrote: ↑
21 Apr 2026, 04:42
I can't say I've ever seen this in synthetic testing or real gaming scenarios.
Discorz
VIP Member
Post by Discorz » 21 Apr 2026, 06:50
Maybe you find Smooth Frog's 3D Rotator test helpful. Press "3" or select "Smooth 3D Rotator" in menu. Once inside press "H" to toggle between Auto Rotation Test/3D Rotator. Adjust the fps variable range, period, and rotation speed and off u go.
No Sync Track here, but at least it does the auto sweep for u. Would be nice if this was a feature for Frog Pursuit test as well.
bahamutfan
Post by bahamutfan » 21 Apr 2026, 07:01
Is the 48Hz update that was announced still in the works?
Post by RealNC » 21 Apr 2026, 09:49
bahamutfan wrote: ↑
21 Apr 2026, 07:01
I believe they said no, they didn't consider the flicker below 75Hz in pulsar mode acceptable.
