CriticalHit_NL
Post by CriticalHit_NL » 09 May 2026, 08:44
brownvim wrote: ↑
08 May 2026, 20:21
Tried the new 1.1.6 update on the Acer Pulsar. It wasn’t working correctly on older Nvidia drivers, I thought my monitor was broken with how bad it was ghosting and stuttering. Was trying all sorts to fix it, restarting PC, restarting monitor, disconnecting 2nd monitor.
Updated to latest Nvidia drivers then the ghosting issue was gone.
Only tried Pragmata and Resident Evil briefly, glad it’s fixed and just in time for the new Leon game mode update :)
Thank you for your information Brownvim!
That sounds good, I'll keep in mind I may need new drivers (596.21 currently)
Can't wait to see it fixed on the Asus as well, then the monitor will finally operate the way it was meant to.
Main System:
i9 13900K @ 0.06v undervolt 0x10B microcode / 128GB (4x32GB) Corsair Dominator Platinum RGB DDR5-5400 CL40 XMP / Asus ROG Maximus Z790 Extreme (early 0219 bios, Sept 2022) / Asus ROG Astral RTX 5090 OC / 2x 990 Pro 4TB / 3x WDC Ultrastar HC590 DC 24TB / 3x HGST He10 Ultrastar 8TB / 1x HGST 7K4000 Deskstar 4TB / Corsair iCUE H170i Elite Capellix LCD 420mm AIO (6x Noctua NF-A14 IndustrialPPC 3000RPM) / Corsair AX1600i PSU (2025) / CoolerMaster HAF 700 EVO / Asus ROG Strix Pulsar XG27AQNGV 1440P 360Hz / Asus ROG Swift PG279Q 1440P 165Hz / BenQ BL2411PT 1200P 60Hz
Secondary System:
i7 3930K @ 4.8Ghz 1.4v / 32GB (8x4GB) Corsair Dominator DDR3-1866 CL9 XMP 1T / Asus Sabertooth X79 (2012 bios 3102) / EVGA GTX1080Ti FTW3 / 1x 840 Pro 256GB / 1x 860 Pro 2TB / 2x HGST 7K4000 Deskstar 4TB / Corsair iCUE H115i RGB Elite 280mm AIO (stock fans in pull) / Corsair AX1200i PSU (2014) / CoolerMaster HAF XM
Third System:
i7 950 @ 3.2Ghz turbo / 24GB (6x4GB) Corsair Dominator/Vengeance DDR3-1600 CL9 XMP / Asus P6T Deluxe V1 X58 / Asus ProArt RTX 4060 8GB / 1x 840 Pro 256GB / 1x WD Blue 1TB / Corsair HX750i PSU / CoolerMaster V6-GT CPU-cooler / CoolerMaster HAF 922
Fourth System:
Core 2 Quad Q9550 @ 2.91Ghz / 8GB (2x4GB) DDR3-1066 @ 1098 Royemai (SK-Hynix) / Gigabyte GA-G41M-Combo (Rev. 2.0) @ 343 FSB / EVGA GTX 560 SuperClocked 1GB / 1x860 EVO 500GB / 1x Samsung HD502HI 500GB / Artic Freezer 7 Pro Rev 2.0 / Corsair HX750i PSU / CoolerMaster Elite 331
Anonymous703819
Post by Anonymous703819 » 11 May 2026, 02:52
kyube wrote: ↑
09 May 2026, 08:32
There were no reviews of the new QHD@360Hz models & their (fixed or variable refresh rate) strobing implementation(s) at that moment :)
It seems you interpreted it as an affirmation. I was right to always be interested in PG27AQN.
It's okay, we all have our opinion :)
kyube
Post by kyube » 11 May 2026, 11:12
Sirius wrote: ↑
11 May 2026, 02:52
The PG27AQN suffers from the same issues that these QHD@360Hz Pulsar models do, except that it's strobing is actually done properly.
–Expensive (+600eur for a IPS LCD is simply a scam)
–DP1.4&HDMI 2.0 (forced DSC past 240Hz)
–KSF backlight negatively impacts strobing, especially the 120Hz & 240Hz ULMB2 modes
If you care about sample & hold, 500Hz OLED is in this price budget in Europe.
if you care about strobing, better models exist for a much cheaper price. (ULMB1 & DyAc1/+/2 or 3rd party strobing solutions)
if you care about total image quality (color rendering, contrast ratio), OLED blows LCD out of the water.
I simply don't see a use-case for the PG27AQN & the XG27AQNGV, which I've stated in the original discussion thread & in this one multiple times.
The successors (Pulsar QHD@360Hz models) have a chance to easily eclipse the PG27AQN, at least in regards to the KSF aspect.
Hopefully, the pricepoint drops to normal values (<400eur) & they orient ULMB2 (≥120Hz) & Pulsar to target much lower strobe intervals, then it'll be a worthwhile consideration.
I'm still a bit salty over the lack of HDMI 2.1, when the MT9810 clearly supports it. :)
Mighty_opf
Post by Mighty_opf » 11 May 2026, 13:47
Hi everyone, the release date for firmware 1.1.6 appears to have been updated today: "Updated 05/11/2026 10:09 AM". Does anyone know if this means it's now available for the Asus model?
liquidshadowfox
Post by liquidshadowfox » 11 May 2026, 22:25
Nope, just checked and asus still doesn't have the update
toyosenpai
Post by toyosenpai » 12 May 2026, 04:10
no asus rog yet :(
Anonymous703819
Post by Anonymous703819 » 12 May 2026, 04:54
kyube wrote: ↑
11 May 2026, 11:12
Agreed, except that this doesn't change what i said: Pulsar doesn't make the PG27AQN obsolete and useless given what you're saying here.
While you implied to me a month or two earlier by stating your point several times.
It's still a very good monitor, with or without strobing.
kyube wrote: ↑
11 May 2026, 11:12
Only DP 2.1 Model*.
X27UF5BMIIPPRUZX for ex. handles DSC poorly and the 500hz experience is not really great, in addition to other factors such as a buggy OSD, as usual with Acer.
kyube wrote: ↑
11 May 2026, 11:12
What references?
kyube wrote: ↑
11 May 2026, 11:12
This is purely subjective.
High saturation and an ultra-high contrast ratio doesn't necessarily mean they're better. Many well-calibrated IPS panels have more interesting potential, also, quite a few OLEDs are more aggressive on the lagom test.
In addition to the potential for burn-in in photo editing usage.
kyube wrote: ↑
11 May 2026, 11:12
Strobing on Pulsar is more painful on the eyes. That can be an argument in itself.
CriticalHit_NL
Post by CriticalHit_NL » 12 May 2026, 12:27
Mighty_opf wrote: ↑
11 May 2026, 13:47
I think it was only updated yesterday to update the text that the Acer model has access now, which already has been for some time on the firmware download pages (there is two)
When I first found the 1.1.4 firmware it was 1 day before official release, when 1.1.6 launched there were apparently two firmware update pages each which displayed a different text. Now recently the Acer received it but that customer support page hadn't been updated yet.
It seems like these things are updated a little bit ad-hoc with some inconsistency, so I am checking all three daily.
Main System:
Secondary System:
Third System:
Fourth System:
liquidshadowfox
Post by liquidshadowfox » 12 May 2026, 12:46
How do you see if the firmware updates are available for asus or acer a day before? I don't know if the firmware is available unless I put the monitor in firmware update mode and go through the flow on the browser.
UnDeRTLaKeR
Post by UnDeRTLaKeR » 12 May 2026, 14:58
Does anyone have the issue ?, the display is not detectable by DisplayWidget Center or Armoury Crate.
