Hello, I have been lurking here for awhile trying to solve a problem, but have been unsuccessful.
I am using the BenQ ZOWIE XL2546K, and the problem I am experiencing occurs in the game apex legends when I move my mouse to look around vertical lines appear. I think from what I read it could be something called inversion artifacts or screen tearing.
V-sync does not sound attractive due to the input lag.
I am disappointed with my purchase of this monitor because of these tears or lines I keep seeing while playing. It has been frustrating not being able to eliminate them.
I would love to have some guidance on my issue. Should I just buy a new monitor or is there a fix?
Vertical lines appearing
Re: Vertical lines appearing
This is a LCD voltage inversion artifact.
See this thread.
It appears as chessboard or lines patterns during scrolling / panning / turning.
It can be fainter or stronger, but often ever-present on very fast TN panels.
No solution to this, except to play the monitor lottery. IPS panels are more immune to this than TN panels, so high-Hz IPS is the way to go if you hate this artifact. So it is often a game of tolerate-the-artifact, try another specimen to see if the artifact is fainter, or switch panel technologies.
If it's blatantly bad, there is a case for RMA. If you can pursuit-photograph or video the inversion artifact (wave your iPhone/Android while recording video, at the same hand movement speed as the lines scrolling) , it can help me determine if it's within normal parameters or is very blatant RMA-worthy.
But since you say you only see it during scrolling, it's probably within normal parameters.
See this thread.
lapods
Thank you for your input. Is it possible for you to recommend a monitor with high-hz ips?Chief Blur Buster wrote: ↑07 Nov 2022, 01:13This is a LCD voltage inversion artifact.
See this thread.
You might perhaps want to consider the ViewSonic XG2431 -- a Blur Busters Approved 2.0 model -- www.blurbusters.com/xg2431
That said, there are many other very qualified IPS panels that have zero texturing artifacts from LCD inversion circuitry.
