Do I Have To Test New Monitors for Frame Skipping?
Mark Fable
Post by Mark Fable » 06 Nov 2022, 15:57
My understanding is that frame skipping may only occur after monitor overclocking, so do I need to test new monitors for frame skipping or is that a non-issue with monitors at their native refresh rate?
Re: Do I Have To Test New Monitors for Frame Skipping?
Post by Chief Blur Buster » 06 Nov 2022, 19:33
Mark Fable wrote:
06 Nov 2022, 15:57
Generaly, it is a non-issue 99%+ of the time.
Some models had firmware bugs that caused frameskipping at their native Hz, though most of them had workarounds.
Mark Fable
Post by Mark Fable » 07 Nov 2022, 12:35
Chief Blur Buster wrote:
06 Nov 2022, 19:33
Mark Fable wrote:
06 Nov 2022, 15:57
Thanks. I did go ahead to test my monitor just in case and I believe there are no skipped frames. What do you think? I attached a picture for your reference.
Also, just to clarify, frame skipping outside of the realm of monitor overclocking is only caused by a firmware bug, correct?
Post by Chief Blur Buster » 07 Nov 2022, 21:40
Mark Fable wrote:
07 Nov 2022, 12:35
Correct.
And yes, your monitor is fine at 144 Hz!
