pg27aqdm screen flicker when shutting down computer&switch source from pc, at 1440@240hz@10bpc
dfr1238
Post by dfr1238 » 10 Oct 2023, 23:01
Update: ASUS customer service has sent me the MCM104S firmware specially compiled for this problem. After the update, this problem no longer occurs.
Kinda look like this, is normal? and does it effect panel life-span?
Screen
Model: PG27AQDM
Firmware version: MCM104, update firmware via PC.
Connection: DisplayPort(1.4)
Sec-screen
Model: Optix MAG274QRF-QD
Connection: DisplayPort(1.2a)
Computer Equipments
OS : Windows 11 x64 Home Edition, build 22621.2361
GPU : MSI GeForce RTX™ 4070 Ti SUPRIM X 12G
GPU DRIVER : 537.42
NVIDIA control panel settings:
PG27AQDM
  • V-Sync : G-Sync compatible mode
  • Resolution Setting : 2560x1440@240Hz, RGB, 10 bpc, Full Range
Optix MAG274QRF-QD
  • V-Sync: Traditional Fixed
  • Resolution setting: 2560x1440@120Hz, RGB, 10 bpc, full range
Tried and true troubleshooting:
  • Reinstalling the graphics driver to the latest version did not work.
  • Refreshing the firmware through the computer did not work.
  • Replacing the DisplayPort cable did not work.
  • Waiting a few minutes after power shutdown and reconnecting, and waiting for the auto-triggered pixel cleanup in standby to complete but it didn't work.
  • Turn off the secondary monitor (But DP cable is still connected, power still plug.) but it doesn't work.
  • Before using the PG27AQDM, I had not experienced this problem when using the Optix MAG274QRF-QD for almost a year (one month if only counting the monitor with the current GPU). However, the Optix MAG274QRF-QD is 8 Bit+FRC and is DP 1.2a
It seems to be a successful but not perfect temporary solution
  • PG27AQDM resolution change to 2560x1440@240Hz, RGB, 8 bpc, full range, work fine with 8 Bit and 8 Bit + FRC when HDR On.
Tried another way of replicating the problem without encountering problems:
  • PG27AQDM HDMI connected to Google Chromecast (Google TV 4K) test, entering sleep mode with 4K@60hz HDR 10Bit(Not sRGB) on did not trigger the issue.
  • The issue is not triggered when switching between signal sources on the monitor side and when the monitor is turned off from monitor power button.
dfr1238
Re: pg27aqdm screen flicker when shutting down computer&switch source from pc, at 1440@240hz@10bpc
Post by dfr1238 » 11 Oct 2023, 11:13
Update:
After a series of tests
NVIDIA GPU (same 4070Ti)
  • The replication rate of the problem is greatly reduced when using 1440@240@10 bpc on a single screen.
  • The problem is still reproduced with the same probability when the primary monitor (PG27AQDM) is connected by DP and the secondary monitor is connected by HDMI.
AMD Internal Graphics (AMD Radeon(TM) Graphics)
  • The problem cannot be replicated when using a single screen.
  • This issue cannot be replicated with dual monitors (secondary monitor connected to NVIDIA GPU and AMD internal Graphics ).
Post by jorimt » 11 Oct 2023, 15:42
dfr1238 wrote: ↑
11 Oct 2023, 11:13
1. Displays in DSC mode can introduce multi-monitor issues due to bandwidth limitations, etc.
2. Random black screen flicker is currently a known Nvidia driver issue:
https://us.download.nvidia.com/Windows/ ... -notes.pdf
Whether the above is contributing to your particular issues on your specific model is the question.
Have you tried setting the PG27AQDM to 240Hz 2560x1440 8-bit to rule out DSC? Because that should prevent DSC from kicking in. You can also check to see if your monitor OSD has an option to disable DSC.
Displays: ASUS P27UCWM, LG 48C4 OS: Windows 11 Pro Case: Fractal Design Torrent PSU: Seasonic PRIME TX-1000 MB: ASUS Z790 Hero CPU: Intel i9-13900k w/Noctua NH-U12A GPU: GIGABYTE RTX 4090 GAMING OC RAM: 32GB G.SKILL Trident Z5 DDR5 6400MHz CL32 SSDs: 2TB WD_BLACK SN850 (OS), 4TB WD_BLACK SN850X (Games) Keyboard: Wooting 60HE v2 Mouse: Logitech G Pro X2 SUPERSTRIKE Sound: Creative Sound Blaster Katana V2 VR: Beyond 2, Quest 3, Reverb G2, Index Consoles: N64, Analogue 3D, Dreamcast, PS2, PS3, PS5 Pro, Switch 2, Wii, Xbox, Xbox 360, Analogue Pocket + Dock Scaler: RetroTINK 4k
Akso
Post by Akso » 11 Oct 2023, 16:23
jorimt wrote: ↑
11 Oct 2023, 15:42
dfr1238 wrote: ↑
11 Oct 2023, 11:13
I was thinking but does 10 bits takes more bandwidth than 8 bits ? Never got an answer on the internet for it.
Post by jorimt » 11 Oct 2023, 17:06
Akso wrote: ↑
11 Oct 2023, 16:23
Yes, it requires DSC on your model.
See:
https://pcmonitors.info/reviews/asus-ro ... ifications
*10-bit can be selected in the graphics driver at any refresh rate, up to the native resolution using DP 1.4 (with DSC).
Also see:
https://www.reddit.com/r/OLED_Gaming/co ... &context=3
I tested the Asus and the LG model, and I kept the LG because HDMI 2.1. I couldn't use DLDSR 10bit at highest refresh rate with the Asus model, probably because DLDSR isn't supported when DSC is in use.
dfr1238
Post by dfr1238 » 11 Oct 2023, 19:48
jorimt wrote: ↑
11 Oct 2023, 15:42
dfr1238 wrote: ↑
11 Oct 2023, 11:13
8 bpc mode was normal without any issues. So, I was thinking about that driver glitch too.
The OSD has options to choose the Displayport version, 1.2 and 1.4
dfr1238
Post by dfr1238 » 11 Oct 2023, 20:31
jorimt wrote: ↑
11 Oct 2023, 15:42
dfr1238 wrote: ↑
11 Oct 2023, 11:13
Is this a model-specific issue or is it a general issue when DSC is enabled?
Yes, I'm speculating on this part. Because there is no problem in 8bpc mode.
It’s just that it specifically states a black screen instead of an error like the one in the video, so I’m not sure.
Post by jorimt » 11 Oct 2023, 21:31
dfr1238 wrote: ↑
11 Oct 2023, 19:48
DisplayPort 1.2 mode will only support 2560 x 1440 at a maximum of 144Hz, so there's no reason to switch to it. Keeping it at 1.4 and switching to 8-bit will disable DSC mode on your monitor while maintaining 1440p at 240Hz.
dfr1238 wrote: ↑
11 Oct 2023, 20:31
General issue.
dfr1238 wrote: ↑
11 Oct 2023, 20:31
Likely just a general description of DSC issues on the latest Nvidia drivers.
If you want to rule the driver out, you can temporarily download and install a version from before the issue existed (I don't know that version off-hand).
dfr1238
Post by dfr1238 » 11 Oct 2023, 21:41
jorimt wrote: ↑
11 Oct 2023, 21:31
dfr1238 wrote: ↑
11 Oct 2023, 19:48
dfr1238 wrote: ↑
11 Oct 2023, 20:31
General issue.
dfr1238 wrote: ↑
11 Oct 2023, 20:31
Then I guess I'll just wait for the driver to fix this.
There is no big impact on the current use, mainly because the performance of 8 Bit + FRC in HDR seems to be close to that of 10 Bit, at least it is difficult for me to tell.
Another question I would like to ask is, will the performance of using 8 Bit + FRC on a native 10 Bit panel be better than that of a native 8 Bit panel?
Post by jorimt » 12 Oct 2023, 08:59
dfr1238 wrote: ↑
11 Oct 2023, 21:41
8-bit + FRC can be virtually indistinguishable from native 10-bit outside of some test patterns even on an 8-bit panel, so it certainly shouldn't be worse on a 10-bit panel, but probably not notably better either, since the 10-bit panel will probably be running in 8-bit mode with FRC anyway.
