Why my Timer Resolution is off by 0.0001 ms?
RealTweaker
Post by RealTweaker » 30 Jan 2024, 17:17
No matter what CMD prompts i use or whatever i do, my timer resolution is always 0.0001 lower than what i set it to.
This is really really weird and idk if it affects anything, but i really wanna know how to fix that or the reason.
Also in LatencyMon the latency is measured down to decimals 0.16546 0.56323 etc. and i remember before fresh windows install (i have windows 10) it was just natural numbers (im not sure though)
I use SetTimerResolution following this guide: https://github.com/amitxv/PC-Tuning/blo ... -precision by amitxv
evmadic
Re: Why my Timer Resolution is off by 0.0001 ms?
Post by evmadic » 31 Jan 2024, 01:27
Looks like you need to disable synthetic timers and the high precision event timer. Make sure your running cmd prompt as administrator.
5800x3d, RTX 4070 ti, Acer Nitro XV252QF 390Hz
https://www.twitch.tv/evmadic
RealTweaker
Post by RealTweaker » 31 Jan 2024, 16:16
evmadic wrote:
31 Jan 2024, 01:27
Yes brother i have HPET off in BIOS and device manager (On in bios + disabled in windows gives the same 0.0001 issue) and had synthetic timers disabled.
bcdedit enum.png (2.26 KiB) Viewed 9576 times
"bcdedit /deletevalue useplatformclock" does nothing as i don't have it in my windows (AtlasOS) -
An error occurred while attempting to delete the specified data element.
Element not found.
However "bcdedit /set useplatformclock no" turns it off, but does not help with my issue or change anything(?)
I had HPET ON before in BIOS as Fr33thy said u should (source)
However this dude says otherwise so i turned HPET OFF both windows and BIOS and found out that now i can lower my resolution to 5060 instead of 5120 with even better delta. Still of by 0.0001 though :roll:
evmadic
Post by evmadic » 01 Feb 2024, 05:14
Disable HPET - bcdedit /deletevalue useplatformclock
I think this only works when you leave HPET on in bios?
My current and Max timers are both synced at .5 and I only used the above and:
Remove synthetic timers - bcdedit /set useplatformtick yes
RealTweaker
Post by RealTweaker » 01 Feb 2024, 11:23
evmadic wrote:
01 Feb 2024, 05:14
"Disable HPET - bcdedit /deletevalue useplatformclock" that's what i get in return: "An error occurred while attempting to delete the specified data element.
Element not found."
As you can see in my bcdedit /enum screenshot "useplatformtick" is set to yes
Turning HPET on/off in BIOS doesn't fix my issue
evmadic
Post by evmadic » 02 Feb 2024, 08:27
RealTweaker wrote:
01 Feb 2024, 11:23
evmadic wrote:
01 Feb 2024, 05:14
Element not found."
If you turn HPET on in bios and then "bcdedit /deletevalue useplatformclock", do you still get the error?
flowrush
Post by flowrush » 03 Feb 2024, 18:40
I presume this be because of the great rule change that started in Windows 10 2004+. The tweaker Amit explains this in his Github as well.
