Scewin/Grub Hidden Bios Settings
Coldplayer
Hey guys wondering if anyone has played around with Scewin/Grub to change hidden bios settings and wondering if it has made any difference for you guys. Using a 5800x3d/x570 if anyone has done it on the same platform.
Thanks
Thanks
- kriegsnake
Re: Scewin/Grub Hidden Bios Settings
We tried changing various things there, with no success. Don’t waste your time.
- Slender
some things is affect on mouse movement and little input, but it on intel.Coldplayer wrote: ↑07 Oct 2024, 03:37Hey guys wondering if anyone has played around with Scewin/Grub to change hidden bios settings and wondering if it has made any difference for you guys. Using a 5800x3d/x570 if anyone has done it on the same platform.
Thanks
on amd mouse work a lot better, no need change anything in hidden bios.
- Slender
but you can share your nvram.txt, i will check some settings for you.
JimCarry
- Slender
resend it
JimCarry
- Slender
your bios is good
ablemor
Slender, can u check my bios too?
Coldplayer
