Looking for XL2546K default timings
Bobo
Post by Bobo » 05 Nov 2024, 18:06
can someone pls share the default timings for the XL2546K ?
mine look a bit weird:
Bobo
Re: Looking for XL2546K default timings
Post by Bobo » 12 Dec 2024, 07:59
can someone pls help?
MSIfanboy
Post by MSIfanboy » 12 Dec 2024, 15:46
Bobo wrote: ↑
12 Dec 2024, 07:59
I'm not at home, check back in like 12 hours, I'll post it then
MSIfanboy
Post by MSIfanboy » 13 Dec 2024, 02:18
Bobo wrote: ↑
12 Dec 2024, 07:59
here, with controlmymonitor app you can exceed max brightness of 100 with dyac, 130, similar to the blur buster utility tool that makes dyac brighter
Screenshot 2024-12-13 181516.png (17.54 KiB) Viewed 2014 times
Bobo
Post by Bobo » 13 Dec 2024, 18:10
much thanks brother.
can you also post the 1080p timings in the extension block?
keybl
Post by keybl » 07 Jul 2026, 07:09
I decided to check it on my monitor XL2546K
matrix - DI Q250HTN00 A600 (The matrix itself is from 2022, the monitor is from 2023)
I can increase the brightness, but I've reached 200 and don't want to go any higher. What's the limit for this matrix, and could the matrix be damaged if I use a brightness of, say, 150? Or could this somehow affect the lifespan of the matrix?
