Timer resolution becomes 0.5 instead of 0.526 when playing games.
dermodemon
Post by dermodemon » 18 Nov 2024, 03:05
I set my timer resolution to 0.526 for the best delta values.
I use SetTimerResolution.exe to set it and MeasureSleep.exe for the monitoring.
When i am not playing game it is always sits at my 0.526 value. But when i start games it automaticaly sets my timer resolution to 0.5 and my delta values is getting messed up.
What is wrong?
I use windows 11. GlobalTimerResolutionRequests=dword:00000001
P.S. weird enough that only unreal engien games are doing this to me. Cs2 for example doesn't change timer resolution value at all
How can i fix this? And anybody else having this problem?
widow13
Re: Timer resolution becomes 0.5 instead of 0.526 when playing games.
Post by widow13 » 18 Nov 2024, 09:14
dermodemon wrote: ↑
18 Nov 2024, 03:05
What is wrong?
I'd personally say, do not play with timerresolution. It's not worth the time and it 99% makes no difference anyway.
dermodemon
Post by dermodemon » 18 Nov 2024, 11:32
widow13 wrote: ↑
18 Nov 2024, 09:14
dermodemon wrote: ↑
18 Nov 2024, 03:05
What is wrong?
My mousetester results say otherwise. It's clean and flat line when i use this value. But when timer is set to default my mousetester graph looks random and chaotic
widow13
Post by widow13 » 18 Nov 2024, 11:37
dermodemon wrote: ↑
18 Nov 2024, 11:32
widow13 wrote: ↑
18 Nov 2024, 09:14
dermodemon wrote: ↑
18 Nov 2024, 03:05
What is wrong?
If you find it to be working, just go along with it.
Personally through the years I tested a million things to make my mousetester look better and it made 0 difference it the end.(best thing was playing with the affinity tool)
I didn't notice anything change with bad or good mousetester, could be just me ofcourse. Just sharing an opinion.
Post by Slender » 20 Nov 2024, 16:00
what timer resolution use engine?
dermodemon
Post by dermodemon » 21 Nov 2024, 12:56
Slender wrote: ↑
20 Nov 2024, 16:00
i did not understand you :D
Shekoup
Post by Shekoup » 11 Mar 2025, 14:36
you found a solution ?
Hyote
Post by Hyote » 11 Mar 2025, 15:47
bcdedit /set useplatformclock false
bcdedit /set useplatformtick no
Maybe these.
JimCarry
Post by JimCarry » 11 Mar 2025, 18:21
I have win 10 and no bcdedit stuff,i set mine to 0,also i think hpet changes this value maybe if you have the option try on or off?
this .GIF (113.01 KiB) Viewed 11828 times
Post by Slender » 12 Mar 2025, 00:37
JimCarry wrote: ↑
11 Mar 2025, 18:21
hpet can affect on timer value only if useplatformtick be enable.
for you i think 0.5013 best value.
