Remove OS X 10.5 pixel clock limit
- rabidz7
Who should I contact to get a patch written for OS X 10.5 that allows the pixel clock to exceed 165MHz? Can anyone on this forum do it? I am trying to overclock my PowerBook's LCD, but the pixel clock is locked to 165MHz, so I can't go past 85Hz. I can pay up to $600 through PayPal or Bitcoin.
Rabidz7 is a: PowerPC Fan, LCD and x86 Hater, and a Plasma/OLED/CRT/SED/FED Lover
blargg
Re: Remove OS X 10.5 pixel clock limit
Do you have some specs that show that the GPU and LCD panel in that model is capable of a higher rate? Also, what model is it? I've set up custom resolutions on my old PPC iBook in the past, though for an external monitor.
- rabidz7
The screen was able to hit 85Hz without any issue. Refresh rates above that are blocked due to the driver limit.blargg wrote:Do you have some specs that show that the GPU and LCD panel in that model is capable of a higher rate? Also, what model is it? I've set up custom resolutions on my old PPC iBook in the past, though for an external monitor.
