Surround LightBoost fixed in Driver 332.21
Post by Chief Blur Buster » 07 Jan 2014, 17:04
If you use surround monitors, and want to run then with LightBoost, you will want NVIDIA graphics driver 332.21:
https://forums.geforce.com/default/topi ... d-1-7-14-/
It reportedly fixes surround 1440p 120Hz with overclockable 120Hz monitors, as well as it should fix surround LightBoost.
GitDat
Re: Surround LightBoost fixed in Driver 332.21
Post by GitDat » 12 Jan 2014, 00:21
This driver didn't work for me. Using the emitter works but having 3D enabled in the Nvidia control panels kills my frame rates :?
Cougar Conquer 2 | MSI Meg Z390 Godlike | 9900K | NZXT Kraken X72 | 32GB TridentZ RGB 3600MHz | RTX 3090 FTW3 Ultra | Samsung 960 Pro NVMe M.2 SSD RAID-0 | Corsair AX860 | 3DMark Port Royal - 14204 | Windows 10 Pro 64-bit | Triple 32" Samsung CHG70 | Samsung CHG90 Super-Ultrawide Auxiliary
