cs2 feels more stuttery on OLED
Posted: 07 Mar 2026, 10:06
Hello,
I have two monitors that I use for competitive gaming. A pg27aqdm and a Zowie xl2546k.
Well the Zowie is only for cs2 because for some reason on my pg27aqdm, the game feels more sluggish, more stuttery. I mean, even more, since cs2 is not exactly running well for anyone anyway. I can feel it well when spraying. It's not obvious, almost more like a feeling thing, but there is definitely a thing and when you're serious about cs2 you know how that feeling thing is important. At first I was trying 1920*1440 on the OLED but now I tried with the exact same settings that I use on the Zowie, so same resolution, same aspect ratio, same performance.
With the Zowie, I usually use Dyac, so in terms of motion clarity, it feels like it's on par with the OLED one, so I don't think it's a matter of a clearer picture on the oled making the stutters appears worse. I tought that it was the case for a long time, but not so sure anymore. The game feels more sluggish too on the OLED. Kinda hard to explain. Like there is more input lag, but in that aspect the pg27aqdm is supposed to be faster than the Zowie so not sure why.
I have a 7950x and a rtx 5080. Like everyone, I have very bad 1% low, but achieving pretty high fps in classic 5v5 on faceit, between 500 et 700. Tried a cap, didn't really change anything. The thing is, my performance are exactly the same, just the feeling is off with the oled.
I tried to use 8 bits on the pg27aqdm but I don't think there is a way to disable dsc to try, but I think it's probably not be enabled anyway when not needed. (1280*960 240hz)
I usually don't have that kind of feeling on others games, but I basically never use the Zowie for anything else. I know it's a long shot and my solution was just to use the zowie for cs2, but in the optic of wanting to upgrade for a one and only monitor, I would be very disappointed if I have the same feeling while upgrading to a 540hz oled for example. I'm not going pro on cs2, but as someone with a pretty high peak on precedent title, it just doesn't feel right on cs2 and I have no idea why...
