Findings
texre
Findings
Post by texre » 16 Apr 2026, 01:26
I’m sure some of you remember me I use to be in the forum a lot back then. I remember saying that getting all new parts and monitor should help but I’m not sure if that’s the case or not. Before I did that I changed my electrical panel because it was burning out. Changing the panel alone didn’t help but once I got a new pc it felt great. Then I had a house fire lolololol. (Electrical) so I’m in a new house and new pc and parts and my game feels so fluid and great. I’ve been here 5 months now. I’m saying all this to say maybe it was electrical and just a coincidence that my pc felt better after changing most of the parts. Who knows honestly but I’ve been without desync for a year and a half now. I post a lot of clips on YouTube if you were going to ask for vids. (Yt Inevitable) i mainly post overwatch and fortnite. But I do have clips of me playing Val and csgo
MegaMelmek
Re: Findings
Post by MegaMelmek » 18 Apr 2026, 05:03
Hello,
thank you for your post. I am at new place, i bring old PC with me and that PC was exposed to lets say 3 years to the bad electricity. New place improves the feeling but its not even close to perfect. What you suggest to change in the old PC? I have the money but i dont really want spend 4k on new PC and find out its the same. Was there one part that improve the input lag most lets say MOBO? Just to find out…
texre
Re: Findings
Post by texre » 20 Apr 2026, 12:31
MegaMelmek wrote:
18 Apr 2026, 05:03
Hello,
i would just get a new pc clearly my old place had problems with power since it had two electrical fires
Unreazz
Re: Findings
Post by Unreazz » 22 Apr 2026, 12:33
Ohhhhhhhh !!! so buying legit windows license key and new pc was not part of the fix ? Also have u not said back then that u switched ISP as well ?
spkii
Re: Findings
Post by spkii » 23 Apr 2026, 08:38
texre wrote:
16 Apr 2026, 01:26
Im going to another house, i should buy new computer or try with this? (2 years on input lag house). Did you tried bad PC on new house=?
astroasis
Re: Findings
Post by astroasis » 23 Apr 2026, 15:44
spkii wrote:
23 Apr 2026, 08:38
texre wrote:
16 Apr 2026, 01:26
My pc from previous bad house works fine at new place, one thing though is that the PC rgbs got damaged or something from previous house bad electricity, but it's all good now
spkii
Re: Findings
Post by spkii » 24 Apr 2026, 04:23
astroasis wrote:
23 Apr 2026, 15:44
spkii wrote:
23 Apr 2026, 08:38
texre wrote:
16 Apr 2026, 01:26
You tested on new place bad computer and works good for you?
astroasis
Re: Findings
Post by astroasis » 24 Apr 2026, 08:54
spkii wrote:
24 Apr 2026, 04:23
astroasis wrote:
23 Apr 2026, 15:44
spkii wrote:
23 Apr 2026, 08:38
texre wrote:
16 Apr 2026, 01:26
yeah bad pc works good at new place, no more blurriness and lag
