Q27G3XMN + HDR + CRT Shader
All Unidentified Forum Objects go in this area! Any fun alien talk goes in this U.F.O. Abduction Lounge, even topics other than monitors or computers. Introduce yourself!
LB2UI
Post by LB2UI » 24 Aug 2026, 07:17
I am trying to get a good crt quality feeling when playing SOTN for PS1 in retroarch.
I have adjusted crt shader settings and have ended up with this.
I have done color and mask settings but still experimenting before i enable subframe shader in retroarch and then select crt beam simulator shader.
Anyone know of any good settings for 27 1440p HDR screen for emulating CRT?
LB2UI
Re: Q27G3XMN + HDR + CRT Shader
Post by LB2UI » 26 Aug 2026, 05:58
MOV_0000007.mp4
(227.77 KiB) Downloaded 1 time
Weird behaviour when display framebuffer (when the setting low input lag is turned off) is turned on.
When display framebuffer is off then it works great, even in HDR mode.
I wonder if anyone know how i can color/contrast calibrate for a specific crt monitor type or standard.
