Gigabyte MO32U24 Discussion
dabooga
Post by dabooga » Yesterday, 10:54
Surprised to see so little discussion about this screen.
According to Gemini:
"Gigabyte’s implementation (marketed as Aim Stabilizer Sync or Ultra Clear) allows MBR to run concurrently with both VRR (G-Sync/FreeSync) and HDR signals using a two-part approach:
HyperNits Dynamic EOTF Shift: When Aim Stabilizer Sync is enabled in HDR mode, the monitor’s scalar dynamically pushes the mid-tone and highlight EOTF tracking curves upward. It over-drives short-burst peak luminance during the "ON" phase of the cycle to compensate for the light lost during the "OFF" (black frame) phase.
Sub-Frame Timing Synchronization: Rather than using static fixed-width black pulses, the scalar syncs the black frame duration directly to the active frame rate. This prevents the severe flicker and brightness collapse traditionally caused by combining variable refresh rates with strobing.
The Result: You retain fluid motion blur reduction while keeping HDR active, though peak highlights will still sit slightly lower than they would with Aim Stabilizer turned off."
A relatively bright BFI implementation compatible with VRR & HDR? I would've thought this should be generating more curiosity, unless the AI is mis-informed on this particular subject.
Another implementation which sounds promising is the MSI 322UR X24 which is also compatible with HDR, confirmed by TFT Central & DisplayNinja, though seemingly less bright and incompatible with VRR.
Thoughts?
kyube
Re: Gigabyte MO32U24 Discussion
Post by kyube » Yesterday, 11:31
dabooga wrote:
Yesterday, 10:54
...unless the AI is mis-informed on this particular subject.
It misinformed you.
It's the typical 1/2 refresh rate BFI with a maximum effective motion clarity equal to the native refresh rate.
Or more simply worded: When you set the refresh rate to 120 Hz and enable “Ultra Clear”, you achieve a effective motion clarity of 240Hz (4,1667 ms)
The actual OLED techonology to look out for are the new panel-based BFI's, which I believe aren't on the market yet.
Hopefully they'll target more aggressive duty cycles (10:90) on those ones, but I don't have my hopes up based on this information
dabooga
Post by dabooga » Today, 09:13
Yes, no different in that sense, although VRR & HDR compatible.
