Hi, I just got an XL2411z and I have a few questions.
My main game is Dota 2. Should I be looking at 144hz without blur reduction, 144hz with blur reduction + strobe utility, or 120hz with blur reduction + strobe utility + vertical resolution? I'm confused as to what would be best for me. I'm leaning toward the last option because it seems popular here.
Thanks!
						XL2411z questions
Re: XL2411z questions
I am in the same boat here! Dota 2 player and I would like to know what are the best settings.
On 40% brightness and blur reduction off, I noticed that it is hard to read text in game.
It is especially apparent when a hero is moving and you are trying to read the player's name when you hover over the hero.
Will blur reduction + light boost fix this issue? I don't notice motion blur with other things but with text it is apparent.
Thank you!
Amer
Thank you!
Amer
I am playing Dota 2 a lot. Try to reduce the Sharpiness to 5 or 6. If you have it at 10 then its just too much.Amer wrote:I am in the same boat here! Dota 2 player and I would like to know what are the best settings.
Thank you!
Amer
