BlurBusters not properly reporting Eizo Foris 2421
bwana
Post by bwana » 20 Jun 2016, 11:07
I obtained a new Foris 2421 monitor that is 120 hz capable. However, the web page here:
http://www.testufo.com/#test=framerates
only show 30 and 60 hz options. This is with a dual DVI cable as well as a display port cable.
Running Win 8.1 pro on dual nvidia 780Ti in SLI with NVidia driver 368.39
The control panel of the display driver specifies 120 hz. And this page
https://frames-per-second.appspot.com/
shows a difference between 120 and 60 hz.
However, PixPerAn only reports 30Hz!
So I think it's driver related but am not sure.
Q83Ia7ta
Re: BlurBusters not properly reporting Eizo Foris 2421
Post by Q83Ia7ta » 20 Jun 2016, 12:12
send here screenshot of http://www.testufo.com/browser.html
bwana
Post by bwana » 21 Jun 2016, 17:09
bbuster test.PNG (80.33 KiB) Viewed 6378 times
as you can see blurbusters thinks this a 60 hz display
bwana
Post by bwana » 21 Jun 2016, 17:13
and these are my displays
Falkentyne
Post by Falkentyne » 21 Jun 2016, 17:19
Please only use 1 display. Using multiple displays may not work correctly. And Aero and hardware acceleration must be enabled.
bwana
Post by bwana » 21 Jun 2016, 17:37
went back and unplugged the other displays. set refresh to 120 hz in nvidia panel. Now it's at 120 hz as expected. thank you.
DanzoMeteor
Post by DanzoMeteor » 30 Jun 2016, 01:41
You can use multiple displays, but NOT in clone mode . If you clone it, the refresh rate is the lowest denominator. I have my 43" m43 c1 Vizio at 60hz and my Hkc X3 at 120hz. No problem!!
