[XG270] What's best settings to use for comp scene.
leekamon
Post by leekamon » 04 Aug 2021, 05:56
Hello everyone,
I bought one of the monitors that Blur Busters have been working on, The ViewSonic XG270. I was wondering what would be the most optimal settings to use in a competitive scenario. Would it be best to use 240hz mode with PureXP ON with vsync? Would it be better to use 120hz mode with PureXP on, For low crosstalk. Should I just use 240hz mode without PureXp and without Vsync? Should I instead invest in one of those Benq monitors? Should I waited and bought the XG2431? I really just want to know if I made a smart investment. I love the PureXP on, I notice a small difference in my aim, Nothing too drastic at least for me. Tho I feel like it can be improved on more with the correct settings. My reaction time is average I would say. One thing I have hard time on is keeping track of targets with my eyes. My eyes tend to twitch left and right to keep track of targets.
I can run games fairly nice. Im running a i9-10900k with a RTX 3090. Most games I can keep up with the 240 FPS/HZ. Main games I play are Overwatch, Valorant, Fortnite.
Let me know what you guys think. I just want to know what's best settings/things to do to improve my gaming experience with competitive.
revnu
Re: [XG270] What's best settings to use for comp scene.
Post by revnu » 09 Aug 2021, 22:29
Hi,
I also bought a XG270. But like you Im also interessted to know how the XG2431 compares to it. Especially then it come to things like: Input lag, picturequality, Antiblur, etc.
For now I just made PureXO on "extreme" und set my Display to 120hz. Not made this "Low-Lag VSYNC" Trick for now, but FPS Games already look ggod and feel lagfree. Of coure a cant compare. Maybe someone out there who tweaked both Displays to max(FPS gaming) can say if the XG2431 is so much better.
greetz
revnu
Post by Chief Blur Buster » 09 Aug 2021, 23:10
Both are well strobe tuned! The XG2431 is more flexible though and does have better strobe quality at the full 240 Hz refresh rate if you prefer max-Hz strobing. Strobing is an end-user preference, however. Max-Hz strobing usually has the least latency, but has more crosstalk than 120 Hz.
For FPS strobing, I recommend staying at max Hz* for strobing -- competitive gaming while strobing works best at 240 Hz though, while motion quality priorities (where lag is less critical) may warrant 120 Hz strobing which is clearer.
*One quirk specific to XG270. The XG270 will have somewhat better strobe quality at 224Hz due to better overdrive, so you may want to also test the 224Hz mode -- the UFOs are much clearer (fewer duplicate images -- less strobe crosstalk). Create 224 Hz in a Custom Resolution Utility (NVIDIA Control Panel) and give it a try.
If you want to do lower-Hz strobing, both XG270 and XG2431 also support Quick Frame Transport for lower input lag at 120 Hz
revnu
Post by revnu » 10 Aug 2021, 00:45
Hi Chief,
can you look on the screenshots I made and tell me wich one is the right setting? With my old BenQ I always just used the "reduced" timings and made the 1350-Trick after that.
But if I use 224hz, but the games I play dont get above 130fps then it makes no sense right? I put the Display into 120hz, capped the Framerate Limit to 119.99 in RTSS, enabled Fast-sync in NVIDIA-Control panel, and set pre-rendered frames to "ultra". Also I disabled VSYNC ingame (PUBG).
PureXP is at "extreme". So did I understand it right and this Display can put the Panel-hz for ex. to 224hz, but let the backlight strobe with another hz, like 100hz? Is that dependend in the PureXP setting?
revnu
2021-08-10 07_31_35-Anpassen.png (23.05 KiB) Viewed 8722 times
2021-08-10 07_31_51-Anpassen.png (23.92 KiB) Viewed 8722 times
