Alienware 34 QD-OLED UFO Test
ericl
Post by ericl » 16 Mar 2022, 09:32
The first results of the UFO test on the new QD OLED monitor have appeared online and... it's pretty good! (At least, for non-strobbing)
Check it out:
Image #2
(The top line is at 175hz. I'm fairly sure this is the best non-strobbing results we've ever seen)
https://www.pcgamer.com/alienware-34-qd ... or-review/
Discorz
VIP Member
Re: Alienware 34 QD-OLED UFO Test
Post by Discorz » 16 Mar 2022, 10:12
Could of improve tracking and use different camera shutter setting, but it does the job.
Here's another one, a simulation. Look pretty much the same.
mxblue
Post by mxblue » 16 Mar 2022, 12:24
Does that mean this monitor could hold its own in an esports environment? If someone wants a single monitor that can also be used for competitive games as well as a good experience in other apps
Or is input lag higher on this monitor?
Discorz
VIP Member
Post by Discorz » 16 Mar 2022, 12:37
mxblue wrote:
16 Mar 2022, 12:24
There is a chance it has some additional processing latency, but don't take my word for it. Wait for TFTCentral, HUB or RTINGS review first.
lossofmercy
Post by lossofmercy » 16 Mar 2022, 12:52
Discorz
VIP Member
Post by Discorz » 16 Mar 2022, 17:18
Boop
Post by Boop » 16 Mar 2022, 19:06
mxblue wrote:
16 Mar 2022, 12:24
I received my AW3423DW a week or so ago and the monitor works great in eSports titles. I have an AW2521H 360hz and a Viewsonic XG2431 240hz to compare it to and this monitor feels great to play on. I really only play Competitive FPS games, but wanted to try the new QD-OLED tech so I picked it up.
The PC Gamer article doesn't show any latency tests so not sure how much they can be trusted. If I was practicing for LAN tournaments then I wouldn't use 21:9 to begin with and would stick to 16:9 360hz displays. If you play CS:GO or Valorant, you're better off using 16:9 displays IMO.
Also, I played with BFI enabled on the AW2521H and Viewsonic XG2431 and the latency seems to be about the same as the AW3423DW.
DrR1pper
Post by DrR1pper » 16 Mar 2022, 19:30
Curious how HDR 10bit 144hz compares vs. HDR 8bit+frc 175hz.
ericl
Post by ericl » 17 Mar 2022, 09:15
Boop wrote:
16 Mar 2022, 19:06
mxblue wrote:
16 Mar 2022, 12:24
Nice, yes I have the exact same AW2521H 360hz and I ordered the AW3423DW because I wanted to see... I'm glad they are both viable options. I was worried that the drop would be too significant. Can't wait to try out the 34" QD OLED (but sadly, I must wait almost 1.5 months)
